FWIW, I bought a set of jardine forward controls off ebay that were made for the nomad up to 2001 non FI. I got them for $152.50 shipped. These bolt up perfectly and I only had to modify the brake side to get them to work. All I had to do was shorten the master cylinder shaft and turn the lever that hooks to it around. I also had to relocate the reservoir because the master cylinder mounts lower on the bracket. this is also why I had to shorten the rod. If you put a longer hose on it you can keep it where it is. These worked great. The seller must have several sets of these and for the price you can't go wrong. Here are the ones I bought.
http://cgi.ebay.com/ebaymotors/ws/e...item=310236793949&ssPageName=STRK:MESINDXX:IT
