Download the service manual - for free. It should help you out.My Kawasaki ninja 650 won’t ignite. I’m thinking it may just need some starter fluid but does anyone know where the intake valves might be? Or even where I could get some good specs?
From memory, I think that you have to remove the tank to get to the airbox, and then remove the cover and air filter to get to the FI throttle bodies, so I'm not sure that starter fluid is the way to go.
Maybe be specific about the starting issues so that members can help you out.
KAWASAKI NINJA 650 SERVICE MANUAL Pdf Download
View and Download Kawasaki Ninja 650 service manual online. Ninja 650 motorcycle pdf manual download. Also for: Ninja 650 abs, Er-6f, Er-6f abs.www.manualslib.com
alright thanks, I’m kinda clueless about my bike right now so that’s why my question was so vague. But even having a manual would help a lot so thanks!Download the service manual - for free. It should help you out.
Apparently it's possible, but with all the hassle of removing parts as stated above, it's impractical.Starting fluid??..........with fuel injection???
