The task is now complete and wow what a difference to braking and handling. It should have came like this from factory.
Items used:
ZR7 wheel spacer
ZR7 Axle
ZR7 Wheel
ZR7 Speedo drive
5mm spacer
ZX6R(F) brake calipers
ZX6R(F) brake disc rotors
ZX6R(F) forks
M6 washers to centralise the ZR7 mud guard (2 on each mounting point)
M10 washers to centralise the brake calipers (1 on each mounting point)
2x sleeves with inside diameter of 23 and outside diameter of 25.
Once I found the correct spacer size I glued it to the speedo drive to make it easier to mount the front wheel. Also I'm going to get a ZX6R(F) front mud guard as the ZR7 one doesn't sit right. You do have to drill new holes for the rearwards mounts but you have to make a choice between centralising it over the wheel or making the gap between the fork leg and the mud guard paralell. I choose the latter. See below. I'm still bedding in the brakes.
