1 - 2 of 2 Posts
Sorry if someone has already posted this. I broke my clutch lever, ordered an oem replacement, and want to make sure that I correctly do the install. Any help would be greatly appreciated.
Super Moderator
I'm guessing that there is still some of the original lever still in the bracket - as you disassemble it to remove the broken piece, make a point of noticing how it all went together, then reassemble in the reverse order. If it is a cable operated clutch, then you will probably have to slacken off the cable first. Whole job should only take a few minutes.
1 - 2 of 2 Posts
