1 - 13 of 13 Posts
Silver Member
Has anyone tried these? If so what was the improvements and also the negatives. Is there a better alternative. Cost is not as important to me but safety and functionality is. Thanks for your help
I know there are a few people in this forum that swear by them. I just ordered a set myself and will get them installed early next week. I've been riding the bike long enough to notice a difference so I'll be sure to give you my 2 cents.
I have attached a picture of them (in the box) For you to look at:
Don't know about these but I have the Hyperpro fork kit and it's great!
Netlore is that your new jets and shims in the bag?
Aris
Well, I finally got my bike back from the shop. There is certainly an improvement. The front is stiffer now but not too stiff. No more hard dive when I hit the brakes. I would recommend it.
The truth about Progressive Suspension
Folks,
I was going to be part of the R&D effort for ZR-7 project last year. Progressive supplied me with the poop on the springs and a set to go out and try. I never got around to installing the springs.:yell:
Dale Walker of Holeshot Performance worked with Progressive to create his spring product for the ZR-7. When you order the Holeshot kit you are getting Progressive's part number 11-1126.
More info:
Stock ZR-7 springs - 40 LB/IN :(
Progressive/Holeshot Part #11-1126 is 35 to 50 LB/IN:cool:
Progressive Heavy Duty Part #11-1145 is 40 to 65 LB/IN:eek:
I have the Heavy Duty units in the box just waiting to be installed!:mecry: These are the same springs used in the Suzuki SV650 and about 20 other bikes.
The PVC preload adjustment is working pretty good for me right now.
I hope this helps to clear the air about brand P and H.
Philip
'00 ZR-7
Netlore
Netlore,
What Progressive part number did you end up with?
Thanks,
Philip
Fork oil Wt
Scott,
I think all of the spring companies recommend 15 Wt fork oil as a rule of thumb.
Back in the 80's most of the (Honda) bikes where shipping with Automatic Transmission Fluid (ATF). This stuff was some where around 5~10 Wt. I think ATF was replaced with straight 10 Wt by most of the Mfg's.
Good luck!
Philip
'00 Stock oil and PVC preload
Re: Netlore
Pdarnall said:
Netlore,
Thanks,
Philip
Philip,
I ended up with 11-1126 (The HoleShot/Progressive Part)
Scott,
I distictly remember reading the installation instructions and
they specify 15wt.
Silver Member
Discussion Starter #12
is the price the same dfor holeshot and progressive. is one better to order from? i dealt with holeshot in the past but money is money.
Silver Member
Re: The truth about Progressive Suspension
Have you installed them yet? Whatcha' think??
Bowman
1 - 13 of 13 Posts
