sigh, is always a chore for me.
this morning i set to adjusting the clutch lever freeplay. sheesh, replacing the right upper fairing - the small gray piece which conceals the clutch cable mechanism - took forty minutes, as i could not very easily reach behind it with my right hand to hold the insulated nut (?) in place. i dropped it, but it did not fall to the floor, necessitating undoing the lower right fairing in order to search for the lost nut. thankfully i found it lodged behind the cylinder head, but it sure was dark in there. gawd awmighty.
i checked the chain slack, thinking it was too loose, but luckily it was well within range at its tightest point.
so i'm off to the showers then out for a cruise, as the merc is predicted to nudge into the lower 70s.
see ya!
see ya!
