I know how to use a pump :killingme. It's just that I was wondering if I could remove the gas without one. But since you said it should be cheap I guess i can just do it this way.You can get a little fuel pump that is plastic fuel line and a squeeze bulb. It is cheap and you put the receiving container on the floor. Once the fuel starts to flow gravity takes over and drains most of the fuel out as long as the hose is at the bottom of the tank.
If you are not sure how to use it, practice with a sink full of water and a bucket on the floor.
You would be surprised to know how many people can not figure one of these out, because they don't ahve a check valve in them. $3 for the one below. Just like sucking the gas out of a car without getting any in your mouth.I know how to use a pump :killingme. It's just that I was wondering if I could remove the gas without one. But since you said it should be cheap I guess i can just do it this way.
+1, although I would caution you to be dainty while removing the hose from the fuel pump; make sure you get the red clip off, and work the fitting by spinning it as you apply pressure. The fitting on the fuel pump is plastic, and if it snaps you just bought yourself a new fuel pump :\Yah, if you're just trying to get under the tank, and have no reason to actually drain it... You can just pop that little red thing off plug, and yank the hose out. It'll drip a little before it seals up, but it's not a big deal if you have a shop rag handy.
What are you trying to do anyway? What's your reason for removing the tank?
