Really no need at all to use FS with new pipes only.
+1 :yoda:Just block or remove the reed valves. Add an intake and then you have to add fuel.
Nope. But feel better knowing your bike is running smoother and cooler than with the stock fuel settings.I was convinced that I needed PC because I installed a set up cobra strippers....
If you're doing this in steps, you definitely want a "FC" when you install the intake. Intake without a "FC" is not good. Many people start with pipes. For just pipes you don't really need a "FC". Pipes are a visible, audible, "cool" thing. The "FC" is invisible but makes your bike run better while most Meanstreak pipes don't.I just want to make sure Im not going to damage my bike without a FC if I have the pipes and intake untill I can save up some pennies for a FC.
it seemed like you guys were saying you dont really need on but it definitely helps.
Add an intake and you have to add fuel.
