1 - 7 of 7 Posts
On my Versys 1000, I've had the front brake lock when riding, this is gradual so able to bring to a stop, brake lever solid! But Bike isn't moving, I think its the ABS. Garage has already changed some sensors, but wondered if anyone else had any ideas? Bike is 2014.
Will certainly double check, second hand bike to me. Thanks
I believe the problem mostly occurred with cheapo eBay levers on radial master cylinders. Something to do with the reach adjustment mechanism. There are YouTube videos. The front brake would just lock the front wheel while riding then.. down you go.
Discussion Starter · #7 ·
I will take a look at the lever and replace, unsure if its a replacement! At this stage I will give anything a go as riding the bike is becoming dangerous as no idea when it will stop or at what speed. I and the garage thought it was an ASB sensor causing it to apply braking. Once it comes on there is no chance of moving the bike which is a little haor raising! Thanks for this!!!!
1 - 7 of 7 Posts
