1 - 9 of 9 Posts
On my 2007 650r ninja my headlights, tail lights and gauge lights keep flickering tried charging the battery even on a full charge lights still flicker when riding or stopped.
How many volts are you reading at your battery at idle? Does it drop as it idles? Does that number go up or down as the RPMs increase?
I notice mine doing it lateley as well. Had my idle too low so when I would idle, or clutch it wasn't turning enough to keep the volts up. Seems better now.
Check your main power wires for loose connections or other issues. Negative to ground, positive to relay, relay to fuses and fuses to pcm. Idle is not the issue when this happens above 1500rpm.
Mine started to dim when I stopped and yesterday it hesitated when it started and the odo and clock reset itself. Checked everything and battery is toast, not bad for an 06 bike.
1 - 9 of 9 Posts
