Hi, all. Anyone have installation instructions, or know how to obtain them, for the Fire & Steel/Kawasaki light bar K32001-007 for 2003 vn1500-p2 mean streak use?
To install the bar, you sandwich it between the headlight bracket and lower triple tree. It might be easier to remove the gauges also, I think that's what I did.
Mine was used and kind of beat up so I ended up replacing the switch and wiring, but I think there's only one electrical connection on the stock version that gets spliced into the low beam. I used a relay and connected the switch to the low beam and the lights get power straight from a fused connection to the battery. Seems better to me since the lightbar pulls more then the low beam itself.
