Oilfilter change GPX 750 R PROBLEM!!! HELP
Apparently I have some problems making a new thread.......
I Was up to changing the oilfilter. I´ve tried almost everything (I think), except (of course) dismantling the fairing and loosening the exhaust bolts on the cylinders......
It´s a 1989, F1 model. 4 in 1 exhaust. The problem is, that the exhaust pipe is almost right beneath the oilfiltercasing. I, ve tried to take off the bolt that holds the muffler, which enables me to lower the exhaust a little bit, but that doesn´t work. The pipe cannot be separated beneath the motor - I think some kind og glue (don´t know the english word for it) has been put on.
I´ve also tried to separate the filtercover, mounting bolt and oilfence with a srewdriver - but it didn´t work either - they can be separated a little bit but something is holding them togather like rubber or a spring.
HEEEELP :\
