http://cgi.ebay.com/ebaymotors/KAWA...rcycles_Parts_Accessories&hash=item1e5a8498b6
do these guards accept foot pegs?
thanks,,thats pretty much what Im looking for,,I think I read somewhere here the frame is1 1/4? sound right?Doublecheck the frame size but this is all you'd need. Much cheaper too if all you're looking for are highway pegs.
http://www.meancycles.com/Home.asp?...ManufacturerID=0&BikeType=Cruiser&CompanyID=0
LOL,,,,thanks! hope your back in action soon!Just checked with my caliper, 1 1/4" will do it. I'm way too bored being cooped up in the house.
thanks,,looks like the bent ones can give you more of a variation in positions..Depends on how long your legs are. Straight arm stick straight out from the mount, offset have an arm that moves the peg however far away.
Decide how far you can reach and if you want your legs straight or bent a bit.
Offset arm example:
hey streak,,I was looking at the frame tube this morning...where,along that tube would you put the pegs? there are those two frame bolts right where I would guess I would have put them...above them the tube has a bend,below them its tight,,radiator cover,rr brake res,,,would that 1 1/4 clamp fit over those excisting bolts in the tube?Yup. Go sit on the bike and see where your feet would be comfortable. If you're not sure then get the adjustable one, they're just more dough though.
thats cool...but its going to be lots more $$ ..I'd remove the wire clamp just below the 2 bolts and put it there. If you're getting offset pegs anyways then you just use the arms to raise the pegs up a bit if you want them higher.
Here's another option if you're worried about finding a good spot on the frame.
http://www.phatperformanceparts.com/M_C_Enterprises_Hi_Way_Bars_Deluxe_O_Ring_p/mc-deluxe-oring.htm
If you're sitting on the bike balanced in your riding position as if on a straight stretch of highway, then your bike would be hovering about 2 inches above the bottom of the kickstand, Genius!Well if the bike is on the kickstand, it shouldn't fall over. Tim, is this why you fell over last time? 7-27-09 kidding.![]()
M/C Enterprises.... Why are my warning bells going off? Oh yeah... never heard much good about 'em. But, to each their own. Good concept for that mount, but ... eh... :2far:I'd remove the wire clamp just below the 2 bolts and put it there. If you're getting offset pegs anyways then you just use the arms to raise the pegs up a bit if you want them higher.
lol I gotchya, man. Nice work. (Hope you're healing well!!)I merely provide options, but if he wants to send me his money I'd be more than happy to spend it on nothing but the finest for him.
the frame size is 1.350. I used a set of kuryakyn offset pegs and they worked great. I mounted them where the wire hold down is on the brake side. i did cut the the nub off the frame. I have these if you are interested. The shifter side has a few scratch marks on the bottom but you can not see them when they are on the bike. They sell new for around $125thanks,,thats pretty much what Im looking for,,I think I read somewhere here the frame is1 1/4? sound right?
