1 - 19 of 19 Posts
FWIW:
To be able to be successful in this endeavor, you must posses certain things .
1) beforehand knowledge of the working of an engine.
2) able to understand and comprehend changes made and there effect from one part to the other, or system.
3) tools to complete the task at hand. Or a shop that does
4) accurate measurements, this is even more important if you are relaying information to a shop.
5) how to accurately measure components.
6) the specs you have before starting you build, so you will know the effects your changes may or may not have.
To be continued ( back to work).
Sent from my SM-N900T using Tapatalk
An all inclusive plan and desired end state before starting to purchase anything.
this is a good read
The experienced engine builder (Mopar, Harley-Davidson, or Ferrari) knows that the “advertised” compression ratio (suggested by the owner’s manual, piston manufacturer, &c.) is only one of several factors involved in determining how much pressure is developed in the combustion chamber.
This article discusses briefly how to roughly calculate how changes in either cam timing, compression, or both affect low-speed torque and response. Some of the more important factors are:
» Theoretical or mechanical compression ratio (advertised, static, or nominal), including corrections made for changes in the combustion chamber volume due to variations in piston compression distance, changes in piston dome shape such as valve reliefs and flame slots, chamber modifications such as larger valve installations, combustion chamber re-shaping, bore notches for valve relief, alternate gasket thickness, head and/or block milling, &c.
» Intake valve closing point (generally the 2nd number in the cam timing data, given in degrees after bottom dead center, or ABDC)
» Internal geometry of the motor
This last factor is not fully appreciated by most mechanics. The crankshaft’s connecting rod journal (or “throw” ) is offset from the main journal by exactly ½ the stroke length. The geometric relationship between the rod and the rod journal is one not generally understood, but which plays a key role in the motor’s breathing and overall power characteristics.
The ratio of rod length to stroke length (usually represented by the symbol “n” ) is almost always between 2.1:1 on the “long” end, and 1.4:1 on the “short” end. 99% of all motors fall between these 2 extreme limits, with most standard production designs between 2.0:1 and 1.45:1.
An “n” value of 1.75 is considered “ideal” by some respected engine builders, if the breathing is optimized for the design. Except for purpose-built racing engines, most other projects are compromises where 1.75 may not produce the best results.
The percentage of mixture captured, compressed, and burned in the cylinder at a specific point of intake valve closure partially depends on the motor’s rod ratio. The piston’s motion during crankshaft rotation is not symmetrical: the piston speed before & after TDC is faster than before & after BDC, but the difference is not constant - it varies with the rod ratio. Two motors with the same stroke, but different rod lengths, will not have the piston in the same place at the same point of crankshaft rotation. The only 2 exceptions are 0° (TDC) where both strokes are zero, and 180° (BDC) where both strokes are equal & nominal.
By the way, the usual limit of engine speed based on the stress of the reciprocating components is not RPM, it’s piston speed. The formula is:
P = S × R ÷ 6
where “P” is piston speed in feet per minute, “S” is the stroke in inches, “R” is engine RPM, and 6 is a constant. About 4,000 f/m is safe for good-quality cast pistons and up to 5,000 f/m for forgings, for peak power only - shifting, not cruising!
Since this speed is not constant throughout the engine’s rotation, piston speed is only an average. A better method of calculating maximum RPM is based on the point of fastest piston acceleration, and takes into account the rod length (longer rods improve the safe RPM slightly). The formula is:
Z = N2 × S (1 + (1 ÷ 2n)) ÷ 2189
where “Z” is piston acceleration in feet per second, per second, “N” is engine RPM, “S” is the stroke length in inches, “n” is the rod-to-stroke ratio (as described, supra), and 2189 is a constant. A safe limit for “Z” is about 100,000 f/s2, although this will cause ring flutter with 1/16” compression rings.
Long-rod motors (“n” = 1.75 to 2.1:1) will have the piston closer to TDC than the short-rod motor at any point between 90° BTDC & 90° ATDC. Short-rod motors (“n” = 1.4 to 1.75:1) will have the piston closer to BDC than the long-rod motor at any point between 90° BBDC & 90° ABDC.
Short-rod motors have slower piston movement upwards away from BDC on the compression stroke, and will capture more mixture at the same point of intake valve closure. This makes them more tolerant of extended (late intake closure) cam timing.
Longer duration cams generally need more static compression. The usual cam functions (also known as valve events) are Intake Opening Point, Intake Closing Point, Exhaust Opening Point, Exhaust Closing Point, Overlap, Lobe Separation Angle, and Valve Lift. The only one which affects cylinder pressure directly is the Intake Closing Point - where the intake valve has just closed ABDC at the beginning of the compression stroke. Intake valve closure after BDC (present in all modern cams) always causes some of the intake mixture to be compressed backwards out of the cylinder by the rising piston at very low speeds. Almost all high-performance cams use extended (later) intake valve closure as a method of increasing peak power. Late (radical) intake valve closure causes some mixture to escape even at moderate speeds, reducing cylinder pressure during the operating range (at the lower end of the torque curve). The point in the engine’s RPM range where this reversion stops and full-stroke capture (or more!) occurs is frequently the torque peak (never after it), and depends on many factors, including cam timing, port efficiency, mixture velocity, manifold runner & port cross-sectional area & volume, resonance, harmonics, exhaust system design, &c. I have no method of applying math to these factors - it’s too complex!
“Add 15” is from David Vizard’s guess that the common flat tappet race cams are effectively about 30 degrees shorter than their nominal duration: 15° from each end.
With only engine vacuum as the drawing power, .050” duration is useful to determine when the intake port starts working.
However, since the force at work here is the rising piston ABDC, back-flow takes place whenever the valve is cracked open, and trapping (compression) only begins when the valve is fully closed - perhaps 5-10° later than the “plus 15” input.
The JavaScript calculator uses 2 errors in opposite directions, which accidently more or less balance out, but the result does not match actual conditions. Only the most violent ramps have only 30 degrees difference between nominal and .050” duration, which means that the intake closing point input is too conservative (early), resulting in a longer stroke than accurate. This is balanced by use of 1.1875 as the exponent for the corrected CR, a polytropic value used in preference to the traditional adiabatic value (1.4) for the ratio of variable heats for air and similar gases at the temperatures present. The usual exponential value for calculations is 1.2 to 1.3 depending on the engine.
This low exponent means an (incorrect) longer stroke is multiplied by an (incorrect) lower CR pressure value - but they don’t zero out.
Using VE is pointless - at cranking speed all engines are 100 VE - the effective stroke is filled 100% since there are no intake restrictions. Therefore VE at cranking and low speed is 100. DCR at any speed near the power peak also shows nothing, since reversion back through the intake has (almost) stopped, making the effective stroke the full stroke, and restoring the CR to static +/- VE.
The trapped volume, effective stroke and DCR vary quite a bit with a change of only 10° in the intake closing point. A valve open only .005” will leak when pressurized, and at cranking speed the leak is fast enough to permit the volume between BDC and IVC to escape almost completely until the valve actually touches the seat.
Some engines with small valves, short cams and rapid cranking speed will be under vacuum and not pull 100% of the effective stroke (100 VE between IVC and TDC), but will also not bleed out all volume between BDC and IVC and have some light residual pressure as the valve closes. The exponent depends on too many non-quantifiable factors, especially heat loss through the jacket and normal operating temp, but between 1.2 and 1.3 is favored by most calculator authors.
The calculator is best used to predict & compare changes in variables in an individual motor, not as an instrument of measurement, or comparison between different motors. The linear nature of the input data vs. the highly varied conditions in different motors will always result in misleading figures. Even if the intake valve closing point is exact, the amount of flow reversion vs. capture will still vary between different motors due to flow characterictics between valve seats, rocker arm ratios, rocker geometry, valve head shapes, &c.
If you have (or plan to install) a long-duration cam, you can (and should) regain some of this lost pressure by raising the compression ratio, but the 2 effects do not always “cancel each other out” - you can’t get something for nothing. Even though a higher compression ratio will give you back a higher pressure gauge reading, the power may still be lower, at least at low to moderate speeds.
DCR Errors
“Dynamic Compression Ratio” (DCR) is offered (elsewhere) as a method of approximating how much power will be lost by extended intake closure (i.e., cylinder pressure is reduced). DCR is very useful in predicting what octane is needed at lower speeds to help setting idle (initial) spark vs. advance curve length, stall speed, &c. However, this is only partially accurate due to several errors and misconceptions.
1. The actual power loss is only present below the points where both full capture (where intake reversion ABDC stops) and positive flow-through at overlap occur (although these may not be close together, depending on engine design). Above that point power is increased (over the milder cam), either by improved volumetric efficiency (and cylinder pressure, since a larger percentage is trapped in the cylinder), higher RPM reached @ the same efficiency level, or both.
2. The power loss is not solely due to reduced cylinder pressure (which is the output of the Kelley, RSR &c. DCR calculators), since the lower pressure is also acting through a shorter effective stroke (measured from intake valve closure ABDC) and therefore suffers from two reductions. My own method factors in the effective cylinder displacement as well, for a closer approximate at how much power is developed at low speed.
3. DCR is widely considered to be an accurate barometer of knock resistance (e.g., “up to 8:1 DCR can be used with XX octane”, &c.).
This is not true, and not safe, since (in a high compression motor with its DCR reduced by late intake closure) after the early low-pressure period expires (at the beginning of the torque curve) actual combustion pressure will be at least as high with the bigger cam than it was previously - even though the DCR is lower, and therefore suggests that lower octane is safe. However, in a motor with 14:1 static CR the gas pressure at its torque peak is not at all reduced by a very late intake closing point, although the (lower) DCR may indicate that 92 octane &c. is sufficient.
Since the knock will only occur at high speeds it may not be audible, and will reduce power (lower MPH) even if no damage can be detected. In my opinion, the power sometimes gained by retarding spark in high gear is actually an attempt to recover some of this loss - but would be better served by reducing the static ratio slightly.
DCR is a curve or slope of cylinder (not combustion) pressure, with Position 0 (the absolute low end) at cranking speed, then a small rise to idle speed, then another rise to the capture point &c. After this point (and especially near the torque peak) the static CR becomes more important, since approximately the full stroke length and nominal swept cylinder volume (or more, depending on VE) is captured and compressed at (below, at, or above) the nominal static ratio, regardless of the intake closing point.
Any cam will determine the “slope” (or rate of rise) of the DCR curve. A long-duration cam with its attendant late intake closing point will have a high degree of rise, a mild cam less, &c. A longer cam will also extend (stretch) the range of RPM that the slope covers, sometimes over several thousand more RPM.
The static ratio determines the height of the cylinder pressure line at Position 0 (cranking speed). With high static ratio the entire curve is higher, with the curve’s upward intensity being governed by the intake closing point.
It’s possible to design a DCR that looks promising, but will not provide any more power, by assuming that there is no limit to either static ratio or intake closure - and, of course, neither is true. Some motors cannot turn fast enough (due to stroke length, weak valve gear, high reciprocating weight, &c.) to reach their capture point if the intake closure is too late, and will produce more power with more conservative cam timing. A motor with limited static ratio (flathead) must conserve cylinder pressure by limiting intake closure for the same reasons.
Another error in use of DCR calculations for low-speed power prediction lies in the fact that a smaller volume of mixture being compressed to a higher ratio. Even though the pressure gauge reading taken during cranking or idling is higher, the total of cylinder pressure times the actual mixture volume captured may still be lower (compared to the original milder cam and moderate compression ratio).
To sum up: DCR a useful tool, but widely perceived to be of greater worth than can be supported by physics.
As a note: the gas present in the combustion chamber @ TDC is presumed to be non-combustible exhaust gas remaining from the previous cycle, and is therefore not included in the mixture volume for our purposes. At high engine speeds (under certain conditions) overlap does cause this remainder to be partially combustible, but this is not true at cranking to moderate engine speed.
In short, a cam change can’t be “cured” completely by raising the compression ratio, but it’s still an excellent idea. The “V/P (“Volume/Pressure”) Index” , which is the subject of this Tech Paper, will not predict maximum torque or power, but still provides useful information about conditions present in the motor at cranking speed. These same conditions generally affects low-speed response & flexibility, knock-resistance, &c. for spark advance settings, torque converter stall speed selection, axle ratio choices, &c.
Another useful purpose is to anticipate the effect of higher elevation on cylinder pressure. Perform a calculation (as described below) first, then another substituting a lower value than 14.7 psi for “Atmospheric Pressure”. Compare the results to estimate how much adjustment to the nominal compression ratio is needed to (partially) compensate for the lower air density. Click here for a calculation based on differences in atmospheric pressure: High Altitude as a Factor Affecting Cylinder Pressure
V/P Index
A reasonable estimate of the relative effects of compression ratio, rod ratio, and intake valve closing point at cranking speed can be made by use of a simple formula. Although a “power” (exponent) is used in the formula, most pocket and on-line calculators have a function to permit a fractional exponent to be entered (use Microsoft “Calculator” in W2K, &c. It has this feature - to use it, select “Scientific” view). Try it out - it’s not that difficult!
Given:
» Atmospheric pressure = 14.7 psi (pounds per square inch, or 29.92 inches of mercury). This is a constant for our purposes here at sea level, but should be adjusted downward for extreme elevations.
To convert psi to In. Hg, multiply by 2.036; to convert In. Hg to psi multiply by .0491.
» Intake valve closing point (ABDC). At cranking speed, intake flow reversal still takes place until the valve is actually closed, so the “paper duration” (nominal) closing point is used for calculations. For intake closing points of common MP factory camshafts, click here: MP Cam Charts. By the way, at operating speeds the general consensus is that the intake valve is not effectively open until valve lift reaches .050”.
» Theoretical compression ratio. I have found that (in general) manufacturer’s nominal compression ratios are a bit optimistic, and that for purposes of calculation about 5 to 10% should be added to the chamber volume as a correction for loose factory tolerances. For example: a big-block 906 head is nominally 78.5cc. In practice, the volume is generally larger, up to 85cc. The calculations made below assume accurate chamber volume - if you're not certain of your actual chamber volume and use your original (nominal) compression ratio when calculating, your actual cranking pressure will be a bit lower than the figures resulting from the formula. Click here to review the factors, as described, supra: Factors Affecting Compression Ratio.
» Stroke remaining at intake valve closing point, which is determined by the engine’s stroke, and rod to stroke ratio (“n”). This is calculated by dividing the rod length by the stroke length. To find the rod ratio of common Mopar engines, click here: Mopar Charts.
Results:
» Corrected (true) compression ratio.
» Cranking pressure, absolute (in psi, zero elevation std.).
» Gauge pressure (in psi, zero elevation std.).
» Corrected cylinder volume (cylinder displacement trapped when the intake valve closes).
» V/P Index
The V/P Index is a mathematically-derived figure, the product of the corrected volume and cranking pressure. It’s a useful barometer of the motor’s low-speed power, and may be solved with new variables for a “pre & post” analysis when modifications are contemplated. Anyone planning a cam or compression ratio change would definitely want to know how much the low-speed flexibility would be affected. Some useful insight may also be derived as to the motor’s tolerance of pump-quality gas (ping & knock resistance). The results of these comparisons are generally quite surprising!
To calculate the V/P Index for a specific motor, you’ll need the exact piston position at all relevant crank positions from BDC to about 90° ABDC, the compression ratio, and the intake valve closing point.
Lol. I didn't post the complete page. It's a very good read
Cam Timing vs. Compression Analysis
Here it is
Colin, even though that was written in English, that was like reading directions in French, Spanish & Chinese bro. I'm embarrassed to say, I have no idea what all that means. Lol
Your Kill'n me Smalls!
It sure wasn't anything I could put on paper, found it, and what it eludes to is how complex and how everything must work within an engine to be able to maximize reliability and power. Just adding a big cam or putting some higher compression pistons may not be the best . You have to maximize everything. Rod to stroke ratio is a big deal as well as anything else. Piston speed is what kills rods and pistons. Detonation as well. Forged pistons can handle a little more detonation than cast but over time its a killer. Getting the correct A/F at high loads is also critical, Any way its a great read IMO The tighter you can run the quench the better, but this too has to be right or you got trouble. you will always have rod stretch to deal with, piston rock to deal with too. I run my personal engine very tight on quench, yea still get the occasional detonation when its hot and pulling hard but its manageable. new build will be a little different in that compression will be around 12:1. With the stock 1500 cams detonation will not be a problem.
I had hoped I would be able to go crazy and build the big engine , but not sure I can afford it or be able to get the cam grind that I need. We will see, still early!!
Going to carb with the thunder billet intake though will change everything. No more ecu restrictions, rev limit restrictions. I feel this will be night and day improvement.
Speed, one of the most costly mistakes I ever made was in communication with my Machine shop.
I will spare everyone of the details, but as we work on our metric bikes, its very difficult to not be converted to measuring things in milometers.
Your machine shop might not understand that. When you send apart with instructions to "Please remove .050......" Be real sure to write in. or mm! Unless someone knows motorcycles, this might not be obvious to them, and you might end up with a beautifully ported and flowed paperweight.
Especially useless now since we dont even have papers, its all computer.
Discussion Starter #9
I agree 100%
Hope it wasn't this costly: CNN - Metric mishap caused loss of NASA orbiter - September 30, 1999
I don't understand. When I was in school, 1975, the us was converting to the metric system. Has this been delayed?
And then there was the affinity for old British motors so the need for the old English standard of Whitworth. Still got some of those around. Marked like SAE with a W after it.
Mad, was the Whitworth the same as "British Standard"?
I remember working in a Snap on Tools warehouse. One section was for British Standard. In seven years, I sold one socket. I was excited to have done so, then the guy returned it and traded for 8mm metric.
yep same thing
Lol reminds me of a funny story of my old boss who has an old BSA and needed torque specs so ordered an original British manual. In it he read the Process for tightening the bolts on the head I believe, and it said in there, word for word, "tighten and then give a final wrench" WTF haha wonder why the old British bikes leaked!
I disagree. It takes more than know how. For example, mechanical engineering degree from Texas A&M University or a B.S in Engineering - Electronics might at times, just land a tech job or as a tech supervisor. For that, you have to pass, every math class.
2018 Kawasaki ZX-10RR 454.2 lbs. Wet; 4.5 g
Race Ready 998cc
⦁ Kawasaki Quick Shifter (KQS)
⦁ Kawasaki Launch Control Mode (KLCM)
⦁ Kawasaki Intelligent anti-lock Brake System - ABS (KIBS)
⦁ Kawasaki Sport Traction Control (S-KTRC)
⦁ Kawasaki Corner Management Function (KCMF)
Dealers require people, with prior experience in mechanics, electronics, aviation electricians, aviation mechanics & those, with tech college diplomas to go, to their own school for training first. Those with degrees are managers. A home build will not turnout as good because pro shops have dynos, full machine & paint heat coating shops. It would never turnout the same. In a pro shop like that, a degree bearer from Texas Tech or Texas A&M might end up just installing turbocharging systems in a shop. BUY A NEWER USED BIKE THAT WORKS & JUNK THE OLD ONE. IF YOU CAN'T AFFORD IT, JUNK IT & DON'T BUY ANOTHER.
You're an absolute douche bag and are entitled to your opinion. Stick with whatever group you are with and be pretentious there....
1 - 19 of 19 Posts
