I did some research and found that the 05 636 gauges fit the 650R connector and is a plug and play replacement. I know I need a speedo healer and I've seen some people do this. Just wanted to know if anyone had any advice on where to mount the gauges. I am trying to go for a factory look and I have access to a cnc to make a aluminum bracket. Just trying to hash out where to bolt it up to and how to finish it e.g. heat form plastic or something. Thanks
Discussion Starter #2
Got the gauges installed, the tach works fine, but the speedo is still off. Getting Speedo healer and ft. sprocket today. Going to install and calibrate. I simply used the stock mount points for the 650R gauges, needed to get a 2" bracket for both top holes, and going to have to trim the top cowl to make it fit well, but overall plug and play.
