If you depend on dealers.......you will get ripped off. they want you money and rely on your lack of knowledge. Chain slack you adjust by yourself. Rear sprocket play?. You can check that yourself simply by putting bike on rear lift and move wheel back and forth. Cush drive replacement is very easy,....but of course..you would have to remove wheel.
..........OK, mounting tires is not easy to do w/out their expensive equipment, but other that that,.....I'd do the rest myself......and no, ...I would not get new chain or sprockets,....UNLESS I CAN DETERMINE THERE IS SHARK TEETH ON.
If rear sprocket play is confirmed by myself....I'd buy the cush drive, and simply tell them to mouont new tires and install new cush drive. They should not cost extra.
.....by the way, when I buy motorcycle tires by myself......a rundown car tire shop near where I work, mounts tires for me for $7 US dollar. (I give them $20). Of course, I remove the tire and bring it to them myself. I also balance the tires by myself, with an axle and a couple of shop jacks.
