I noted in another thread that my z1000 makes a 'buzz' at about 6000 RPM on up. With the advice of Tombiker (thanks Tombiker) I figured out that it was the clutch lever. I found a reference to the same thing here .
Both Tombiker and the article suggest that it can probably be remedied with a washer. I went out and picked up an assortment of nylon washers to see what I could do. I removed the clutch lever and tried to fit one of the washers in with the clutch lever to take up the free play.
The washers were all too thick so I sanded the thinnest on I could find down to almost nothing. It was still to thick. I don't think there is enough room to fit in any washer at all. It looks like the vibration may be caused by the bushing and Kawasaki's choice of bolt. The bolt is a regular bolt, not a shoulder bolt. Al of the (2) motorcycles I have ever worked on before had a shoulder bolt (no threads in the middle). There seems to be a lot of free play between the bushing and the bolt.
I endded up just putting some grease on the whole mechanism and tightening it back down to 52 inch pounds. The 52 inch pounds is just a guess, as the service manual didn't have a recommended torque setting. I got the 52 inch pounds from the torque specification for the brake lever bolt.
I'll ride again tomorrow to see if the added grease/ re-torqueing did any good, but I doubt it.
Is anyone else having this issue? I know it may be early, as a lot of people are probably still following the recommended break-in RPM limits, but if anyoner else has noticed the 'buzz' and has been able to fix it, I'd really like to knowwhat they have come up with. Also, does 52 inch pounds sound like the right torque? I'm a really crappy mechanic, but I am slowly learning.
If nothing else, I may make a trip down to the hardware store next week to see if I can find a shoulder bolt that takes up the bushing slack better.
Thanks for any tips or advice.
