intake pieces and after gaskets and install.
yes nice piece for the price. The loose filter is a problem because it does not seal and or filter with it being loose. easy fix though.Nice, yup thats exactly what I did, except I didnt fix the loose filter problem yet. not to hard to get this intake right, looks great and definitely worth it IMO, im happy with mine so far.
no problem on the plugPretty cool looking... How does it breathe and will it be a pain to change the spark plug???
the spike cover holds the filter, have no idea on replacement filters, should never have to replace, just clean and reoil.How is the cone retained? Where do you buy replacement filters?
not surprising, I am sure there is one out there, k/n more than likely has one.yup "shouldnt" ever have to lol although I contacted all the sellers that sell these on ebay about purchasing replacement filters, just in case and ............... none have answered.
thanks it looks like it is part # kn sp-3301d2moto.com has a replacement K&N filter for this intake.
Looking good. Are you taking the plastic air tube out?Long day toady speedracer,, removed the gas tank, blocked off reeds and removed all the plumbing, installed spike air kit, tomorrow I will clean up the left side. Here are some pics. Thanks for all your help!
[/ATTACH][/ATTACH]
yep the one that went from the filter to the right side intake. You may have to remove the intake to get it out. I had to cut off some of it to get it out. You will see what i mean when you look at it . Yes i removed everything that went with the solenoids as well as all the hoses and stuff for the reed valves. I have a copy of the service manual i will send you if i canSpeed racer are you referring to the tube under the spike air cleaner. If so I'm tackling it tomorrow. Did you keep the solenoids, I've doing everything by trial and error and the info I receive from brothers like yourself. I ordered a shop manual so I can learn part names.. lol
I have one i can sell ya. I am using the K&N open filter like the filter on the thunder intake, so i have the complete filter assembly that goes onto the 3" piece.I got my spike put it on and really liked it....I was coming home the last twenty miles of a Sunday 150 Mile cruise and hear something look in my mirror and i see the cone bouncing off the side of the road!! Well I guess the set screws were not tight enough or backed out, even after I took some advice and put lock tight on the set screws. Bummed because now I need to shell out another $100 for a new spike(after looking in the bushes for 45min I gave up and never found it) . Lesson to the the story I think the next one I get I will drill a hole through the flange piece and put a bolt on the inside or get longer set screws. Hope this does not happen to any one else.
yes it does. it will thread in on the rear bottomi have a question about that spike filter also. been looking at that on ebay for while now but i cant tell where the ait temp sensor gets mounted and does it even mount to the base plate
just cap those off as you would anyway. You should have two threaded holes in the bottom of the adapter plate, one is for the intake air temp sensor and the other for the crankcase breather tube.I am installing the cone setup and my throttle body plater is the the same shape as the throttle body, does not have the drop down area for thetwo small tubes, or any of the two rubber hoses any ideas on that and what i can eliminate and it all still work
this kit is a close of the procharger ( i think thats the name) the other is a clone of the thunder. I have the thunder clone but think the one in this link would flow better. ( more direct air into the TB)Is this the ebay kit folks are buying here? Motorcycle Chrome Spike Air Cleaner Intake Filter Kawasaki Vulcan Meanstreak | eBay
just bought this kit. will be selling my other kit cheap. Nothing wrong with the other kit, just like the looks of this one better and think it may flow better.Is this the ebay kit folks are buying here? Motorcycle Chrome Spike Air Cleaner Intake Filter Kawasaki Vulcan Meanstreak | eBay
this kit is a clone of the forcewinderthis kit is a close of the procharger ( i think thats the name) the other is a clone of the thunder. I have the thunder clone but think the one in this link would flow better. ( more direct air into the TB)
yep that is the hose that gets the marble. If you are installing the coasters ( reed valve block off plates ) all of the hoses, valves etc. that is with that system is removed. if you leave that open and still have the reed valves in i would think that would not be good for the engine. That tube was getting filtered air b/4 you put the spike intake on.So, I got Speedracer's handmedown spike air cleaner installed. Not too hard, looks good and seems to work well. One question...
I now have an extra vacuum tube that used to go into the top of the right air cleaner. Red arrow here. I gather that that's commonly blocked off, or the whole vacuum switch is blocked off with plates to reduce backfiring.
I don't seem to have a backfiring problem, so my question is whether it should be blocked off, or if there's a negative effect of leaving it alone.
I am really not to sure how that system worked but i have all that stuff removed from mine. If you don't have the block off plates you can still remove everything and just put rubber caps on the reed box's on each cyl. where the hoses were.That's what I thought, I'll get that plugged asap. I actually wasn't clear on which way the air flowed in that system. I meant to put my hand over it this morning to check, but was in a hurry and forgot.
Thanks.
