Has anyone used the Seafoam Carb cleaner to clean their Carburator? I'm having rough cold starts I feel the carbs are dirty but I cant take them apart yet
I also prefer the chemtool B12, but either way, some cleaner in the tank can't hurt and may do the trick. I was having a little problem with my choke/enricher circuit earlier this season. After putting some (cleaner) in the tank, and repeatedly running it with choke on for a little longer than usual, it helped.
Rough cold starts and carbs were not unheard of. I'd be worried about anything that would clean without damage. I dont thik theres an additive you'll dump in and have it do an amazing job.
Try draining the float bowls first, to see if there are any large particles in there. You can easily do that with the carbs still on the bike. If you find any crap in the drainage (there shouldn't be) there could be a couple of reasons for that we can discuss later. After draining, run some cleaner of your choice from the above options thru the system to see if it helps.
Just read an article about motorcycle carb cleaner. I have researched a lot and found this really fantastic. Hope you guys will be benefited from here.
1 - 10 of 10 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
