So, I recently saw that the cover of my 2013 Ninja 650 disappeared from the parking lot. Because of personal reasons, I haven't been able to ride my motorcycle for a few months. After the cover disappeared, I decided to get on the bike and move it. I am not able to unlock the handle bar! I am guessing it is because whoever took the cover of my motorcycle also tried to steal the motorcycle and messed up the ignition key slot. However, there are no other signs to go by. The handle is in lock position, I can insert the key, but I can't unlock the handle. Other possibility is that there was no tampering but the handle has gotten stuck/frozen due to nonuse.
I have tried oil, wd-40, graphite lube, wiggling the handle rigorously while rotating the key - nothing works. Both the keys I have work on the gas tank and the back seat.
If I assume that the ignition key was tampered with, what options do I have to make things straight? Should I replace the ignition switch and the handlebar will unlock again? What are the considerations? I can't find a proper write-up/video describing the way to replace an ignition switch - it would be helpful if I get some lead.
Also, what are the other options - Can a locksmith help here? Can I somehow unlock the handlebar? I can't take my motorcycle anywhere right now!
Thanks for the help in advance! I can't wait to get on the motorcycle again!
