· 見る
I can only start my bike if it is in neutral. I should be able to start once I have pulled the clutch lever. Does anyone know what the issue may be And how to fix it?
Check that the little switch at the clutch lever is not jammed/faulty. Maybe spray it with a little WD-40 or RP7 and pull/release the clutch lever a few times. Then try to restart.
