1 - 20 of 20 Posts
Maybe somebody might know this one. I have an 07 650 and I was taking the gas tank off and my buddy that was helping lifted the tank too much before I could disconnect the lines and he snapped the tube assy piece that goes into the fuel pump itself (not the red connector piece). My question does anyone know what type of socket or wrench that is used to for the two bolts on the bottom of the fuel pump. I just have never seen anything like it its almost like a helix style or six point but much smaller groves and just doesn't work. Auto part
Auto part
Auto part Brake
Special bolt by mfg. It is part of the pump and not available separate. Pump cost me $210 years ago. That said you can try cutting a slot with a hacksaw for a screw driver or try vise grips to remove the bolts. i do have my old pump around and can send you the part if your lucky to open it up.
Special bolt. They don't want you messing with it. I looked at my pump and there are 2 options. Pump on our bike is rated at 47 psi which is much higher than the normal 30-35 psi. You can remove the bolts and replace them with hex ones withthe same thread. Problem is you have to remove and replace the plate so it doesn't leak. The 47 psi is high but thats the operating pressure. My pump still works but the plastic housing broke reducing the fuel pressure to 30 psi. It ran fine as long as you didn't go wot. Then it starved. I'd buy a new or used pump if you can find one. Or risk getting a gas bath if it leaks on the road.
Are you sure about that? The little indents look way too small.
Yep more specifically it is a external Polydrive. A form of torx.
Reactions: rcannon409
Discussion Starter · #8 ·
Wow haven't looked at this thread in a while and i went to harbor freight they couldn't help and i went to a shop and they said they never seen it before so i decided to file the bolt so it was square and used vice grips and came off with no problem
Make sure you get them tightened correctly. I don't know how you'll find a torque spec for it. Hopefully good-n-tight is enough. You don't want to screw up your fuel system and spray gas around.
Do you have a donor pump to get that part from? What's your plan here?
They're apparently called System Zero screws. There are some other crazy fasteners if you click through that instructable.
http://www.instructables.com/id/Whe...r/step93/Tamperproof-System-Zeroreg-Security/
(I did find that by searching polydrive :))
Discussion Starter · #11 ·
Yea i cant find any torque specs but like you said hopefully tight is tight enough, I mean it barely took any pressure to undue the bolts so its not like its some crazy torque spec. Also, I was able to order the part separately it only cost 30 so way better then 300 bucks and im just gonna have to wing it per say and hope this works. Thanks for all the help
Hey guys and gals, just wanted to throw out some information I had to figure out the hard way. I was doing a frame up restore on my fiance's 650R and managed to drop the gas tank as I was putting her back together. Ruined the paint job I had just sprayed and it broke the stupid plastic piece... Against all advice I prepared a ******* fix and JB welded the sucker back together. This lasted about 5 minutes. Went back to the drawing board and considered tapping the base plate. After about 2 hours of wandering around Home Depot and Ace hardware I decided to try out a copper fitting by tapping the base plate and threading the replacement parts directly into the metal base plate of the fuel pump. I used a 1/4 nipple with a 1/4" to 1/8" reducing 90 and threaded a rubber hose adapter into the 90. I believe the tap was a 5/16 or 3/8s cant remember right now. So after removing the plastic piece with channel locks on those torx heads, I very slowly tapped the base plate. No drilling was required but the tap could only move about an 1/8 of a turn before I had to turn back to clear the cuttings. This created a bit of a mess in the pump outlet line. I should have prefaced with a removed the pump before attempting this procedure. To clear the cuttings I took off the plastic piece on top of the fuel pump by squeezing with the same channel locks as before. Under this there is 2 clips holding the fuel pump solenoid/valve thingy. remove those and give a firm tug, with our bare hands on the silver solenoid piece. This gives direct access to the outlet line. I then flushed the line with water until all of the cuttings were removed. I then laid it out to dry. Once dry I threaded the nipple in tight then put the 90 and adapter on. I tried using the stock fuel line but found it kinked and the engine was running way to lean. I swapped the stock line with some hose from napa and doubled up the fuel line clamps on the adapter because I chose a fuel line that fit loosely over this piece. The size I chose fit snugly over the stock snap connector though. I then snaked the hose around the front of the bottom part of the air box. The hose I selected fit snugly over the stock fuel line piece that is attached to the throttle body. I simply slid the hose on and lightly tightened a clamp over the hose ( plastic piece once again). Started her up and she is running great... I actually forgot the plastic piece on the fuel pump that covers the fuel pump solenoid/valve piece. She seems to be riding better than before honestly but I have rebuilt the clutch, changed the oil, and had the bike down to frame since she was lasted started so it is hard to tell what caused the change in performance. I hope this helps the next person out before you spend 200 bucks on a new pump due to some cheap plastic bs. Feel free to hit me up if you want pictures or more instruction! Planned obsolescence pisses me off so I am happy to pass on the knowledge. Also, if you do not know what most of these words mean (parts tools etc) you may want to grab a mechanically inclined buddy. One last thing BE VERY CAREFUL WHILE TAPPING. This is soft metal and you can easily turn your thread right out as you cut. Tiny bit forward half a turn back every time. Good luck!
Hey everyone, I’m new here and I know this is an old thread but I just bought a 2007 650 today (my first bike) and made the same mistake while trying to get to the air filter. If anyone has an extra piece or any advice please let me know, I would be extremely grateful.
Where did you find the part for$30? I need it to.
1 - 20 of 20 Posts
