Hi I have just purchased a full black widow exhaust system for a 2015 z 1000 is it a case of taking the standard system off and bolting the new one on or is there going to be problems with the 02 sensor cheers
According to their website their systems have a Lambda (O2) sensor plug - Which implies that there is a fitting for the Lambda sensor on the pipes - so it's up to you if you want to run your O2 sensor or not. Unless you are doing some remapping and other mods, it might be better to just plug in the sensor.Hi I have just purchased a full black widow exhaust system for a 2015 z 1000 is it a case of taking the standard system off and bolting the new one on or is there going to be problems with the 02 sensor cheers
