HI THERE
MY BABY IS GIVING ME TROUBLE.... SHE IS STRUGGLING TO START.... I SWING HER CONSTANTLY, THE STARTER MOTOR IS FINE AS ITS SWINGING FAST ENOUGH (I COULD BE WRONG) THERE IS PETROL IN HER, TAP IS OPEN.. SHE EVENTUALLY STARTS AND I DROVE HER TO THE SHOP BUT THEN SHE STRUGGLES AGAIN AND THIS TIME NO LUCK... MY FRIEND CAME TO HELP ME, HE PUSHED STARTED HER EVENTUALLY... THEN SHE IS FINE... I RECENTLY HAD MY CARBS BALANCED, BEFORE THAT SHE WOULDNT STRUGGLE SO MUCH...
ANY ADVICE PLEASE???:)
What is "swinging" ?
How long since the plugs were changed ?
You are using full choke when trying to start cold......right ?
How old is the battery ?
Do you have a small battery charger ?
Put a healthy dose of carb cleaner in the gas; it might work miracles.
Look for Berryman's B12 Chemtool or Gumout.
After they did the carbs, they didn't leave the idle speed set too low did they.
I think you should take it BACK to the people that "balanced the carbs" and see if they can figure it out.
Might be something that they screwed up.
Premium Member
"swinging" may be what they call trolling in south africa.
lose the caps to start please and thank you
if she ran fine before the carbs were tuned that would be the first place to start.
