After upgrading the brakes to 2012 Z1000 spec Ive started to look at the aesthetics of the fluid reservoir. You can see in the pics that its rather large, white plastic piece atop the front end of the bike.
I started looking at different reservoirs and a company called British customs. They make a nice billet item that mounts directly on the Nissin master cylinders.
British Customs' Direct Mount Reservoir is a CNC machines, black billet replacement unit for the front brake reservoir that enhances the design and function of your 7/8" controls-equipped Triumph.
britishcustoms.com
The only issue with these is that theyre tall but otherwise do without the mount and the hose .... neat yeah?
This got me looking into master cylinders themselves and after digging around i found that the most desirable cylinders are the famous brembo RCS 19. They have 19mm or 3/4 inch cylinders.
They aren’t the only ones though and some of the later z1000’s (the rr in particular) are also 19mm if you can find one. Well i got lucky and picked one up on eBay for the same price i got my 11/16inch one. Then i noticed something.... I couldn’t use the British customs reservoir as the RR uses a direct mount reservoir standard and the one i had bought didnt have it attached... no wonder it was cheap. Ive since found these rizoma pieces ct028’s and theyre specifically made to fit direct on the RR cylinder
If your looking for a standard nissin 3/4 inch master then the Suzuki gsxr600’s use them as well as others ... The 3/4 is cast on the bottom of the cylinder... happy shopping !
I also got the ****s and bought some other parts. Ill post pics for those interested.
