1 - 1 of 1 Posts
Hi this is my first post here. I've recently started a project to upgrade my '05 z750s' suspension, and brakes. I'm currently waiting for my Ninja 636 rear shock, and linkage to arrive to upgrade things in the back. I also want to install the Racetech Gold Emulators, and adjustable spring dampening caps to the front forks. This seems to be the most cost effective, and least time consuming front end upgrade. Rather then the frankenstein Z1 triple clamps with 636 Forks, and wheel upgrade.
The question I have, and the reason for starting this thread is this: Are there better front brake calipers out there that will bolt to the Z's stock conventional fork? It seems to be hard to find the answer since 95% of sportbikes now are running inverted forks, and the caliper mounts are different. If I had the time, and more money I would swap the forks to the 636 ones, and run Nissin calipers as opposed to the crap Tokicos.
Any feedback you could give would be appreciated, thanks.
1 - 1 of 1 Posts
