Yep, it's definitely the reflector.
I found that shoving some dense foam through the back of the housing between the reflector and the housing WILL STOP the rattling but I'm unsure as to how hot it gets. But it'll definitely work. I'll experiment with the dense closed cell foam to see how it reacts to heat.
There is that Phillips head screw on the back of the bucket. It serves to firm up the reflector. Tightening it helps, not loosening it.
To clean out the housing I took it in the house and filled it with cold tap water and swished it around then dried it. It looks brand new now.
If the foam seems to susceptible to heat, the only other decent solution would be to drill and insert nylon screws.
