For those high mile riders reading this, do your valves tend to tighten or loosen over time? I'm shimming right now and on some valves have to decide between the low or high end of the spec.
Those newer to the wrenching may wrongly believe that valves always tighten over time. Whether the cam lobe to bucket gap increases or decreases over time is a function of cam lobe wear (widens gap) vs valve seat recession (shortens gap). Some engines are designed so these opposing factors cancel one another out and gaps are held relatively constant. Another factor to consider is the smaller the gap the greater the valve lift and theoretically greater flow and power. Too small a gap, especially on the exhaust side, and heat will buildup and in the worst case scenario, damage a valve.
