1 - 12 of 12 Posts
am doing research on changin over to 636 front end and from what ive seen so far sounds like an 03-04 636 front end will bolt right on to the 650 is this correct? and will it fit with stock fairings/ wheel lock position.. and will i have to change my tire/brakes found a complete 04 636 front end for 270 want to make sure itll work beofre i pul the trigger and buy it
The best setup is 03/04 triples and 05-06 forks. You also need the wheel, axle, rotor, and calipers. Another option is to bore out the bearing pockets of your stock 650 front rim to accept 636 bearings. Discs will work properly and you can save some cash -- also the 0304 front wheel is a 3 spoker, which looks different from your back wheel.
If you use zx10 forks you can keep your wheel.
Wait...huh? Nvm. They changed the forks from 41mm ('05) to 43mm ('07?) so I don't think it'd work. I've heard an 09's is a direct swap, but haven't seen anything on it. Of course...this is the 650r part of the forum....
Hey did you ever change over your 650 front end for the 636 i have access to a dirt cheap front end from my friend its an 04 and would love to swap it just wanted to know if it worked
if you can get the hole 04 front end set up including wheels and bearings, DO IT!!
i wish i had a chance to buy the hole front end set up from the same bike. mine is a mix of 04 and 05 different bikes lol it was a pain in the *** to find the right info of what pieces fit together.
main concern was the wheel and bearings, but if your hook up has all that, you should be golden! it was a pretty easy swap, i did alone in a matter of 4 hours.
GL on the project !
oh and if your planing of keeping fairings than it might get complicated.. i know there are threads in here that show how to modify your fairing to work with the 636 forks.
i dont know much about them cuz my bike likes to be nude :) lol
nice cata fairings. I wish i could afford the set. lol.
just out of curiosity, what was the shipping cost for them?
1 - 12 of 12 Posts
