http://www.scootworks.com/shop.cgi/page=partsexchange.htm/SID=1238631502.31647i sthat a chrome caliper. how much was that if you dont mine me asking.
Just to give you an idea of costs.
can you give alittle more info on why your 05 did not work with 3/4" on each side.What were the issues?Be careful if your Mean Streak is above 2004.
I have a 2005 and widening the rear wheel 3/4 inch on both sides did not work.
I had to send back my wheel to Kosman and redo it.
To work on my 05 I had to widen 1/2 inch on the drive side and 1 inch on the brake side.
The tire was slammed into the driveshaft even after modification of the drive shaftcan you give alittle more info on why your 05 did not work with 3/4" on each side.What were the issues?
Anybody know if Metricfats still has these hubs for sale ?I did find out that Metricfats.com makes a hub that allows you to use any aftermarket Harley rim on our Mean Streaks but then that requires the purchse of the hub and then the rim and tire.
All you need to do is deflate the 200 tire before putting it on, no need to remove the shaft hub. You can't go wrong with the Avon Storm.A 200 would technically fit if you installed it deflated and possibly removed the shaft hub to get it on. Manufacturers don't recommend that size tire on the meanie rim because its too narrow and potentially unsafe. Have people done it? Yes. Should they? You can decide. The tire is also so pinched that you'd not see any size difference between it and a 180 or maybe a tad larger combined with worse handling and a smaller contact patch to the pavement. Personally I will not go wider than a 180 on a stock rim.
ANY MORE PICS OF YOUR MOD FOR THE REAR TIRE?
Nope, it's been done on an SE.It would work just fine but I don't think anyone has done it yet with an SE. You would need to repaint the wheel or else have them powder coated.
