1 - 12 of 12 Posts
Hello guys
My bike is 2017 ninja650
today i start my bike ,everything is normal,then i'm kick in to the first gear but forgot the side stand,its on down position,so the engine was stop.
I retract the side stand,then its wont start again,i tried everything i could,neutral gear or first gear with clutch
the battery is fully charge,13V
i just wonder has anyone got this problem before?
i called the dealer and tomorrow they'll send my bike to check.
IMG 6166
IMG 6167
· 見る
Thanks your response
normally in neutral gear it should be able to start,no matter that switch is malfunction i think?
i'll tell them to check that switch first.
Looking at your videos, also make sure that the battery cables are securely connected to the battery.
Did you ever figure it out? My 650 is having starter issues as well. I was informed by a engine mechanic that it could just use some starter fluid but I’m struggling to find any intake valves.
· 見る
Hi. Welcome onboard. The OP's #6 post says battery life low -so from that I'm assuming that while it held 13V, it was faulty and didn't provide the high amperage required to start the bike.
What specific starting issues are you having?
I actually found out it was my battery as well and nothing with the starter. But I do wanna improve air flow so hopefully this manual will help.
· 見る
I’ve been thinking about a k&n. I’ve heard some good things so apparently it is the way to go great!
K&N have been around for decades. I've used them for 50 years. I'm running a DNA air filter in my Aprilia. It has good feedback online. Maybe search for it in Youtube.
1 - 12 of 12 Posts
