1 - 2 of 2 Posts
What are these wire connections for on the clutch lever, I installed these new clutch and break levers and everything worked great except the plug I had doesn’t fit these, I spliced them and connected them I just wanted to know what the reason for them is, I pulled in the clutch and started fine, I never start in gear so I don’t know what will happen
122609
Discussion Starter #2
Never mind I figured it out if anyone has questions all it does is make it so you can’t start it in gear
122611
1 - 2 of 2 Posts
