1 - 6 of 6 Posts
If you are looking to do the HID retrofit and want to avoid the trouble of opening up your stock headlight assembly, look no further and save your headlights.
I had these on my '13 Ninja 650. I sold the Ninja but the buyer wanted to put the stock headlights back in.
These HIDs are from BKMOTO and are fantastic for nighttime driving. Level cutoff set so that it wont blind drivers from behind. In my opinion, they look a whole lot better than the stock headlights. See attached photos.
Included and pre installed in the headlight assembly:
2 bixenon projectors (low beam and high beam)
2 35w hid bulb in 4300K (pure white)
2 White Halo/angel eye​
Also comes with the following:
2 halo/angel eye inverters
2 slim water proof ballasts (Stuck together)​
Unfortunately, the wiring harness was destroyed by the technician who reinstalled the stock assembly. You can order the same harness from BKMOTO.
The 2 motorcycle wiring harnesses are all you need to make this complete.
Yes. These work.
Yes. The high beams work.
Yes. These are awesome.
No. This is not a scam.
No warranty. Sold as is.
Yours for $150 OBO.
Send me a pm if you are interested.
Damn, what a deal. If I still had a 650, I'd be all over this.
Did you see on the bkmoto site where to order just the harness from? I emailed them last week and have yet to receive a response from them. I ended up using a single hid relay harness I had from a retrofit source kit I removed from my car.
1 - 6 of 6 Posts
