1 - 1 of 1 Posts
Have some parts to fit the ‘12 to ‘16 Ninja 650...(ignore the shock at 9:00)
Lose that never-used back seat and add this factory-made seat cowl. Retail is $214, yours for $100. Comes in factory Red but easily painted to match your color. This is NOT the eBay junk that clips to the seat. Replaces the seat and is removable with your key. Even adds a little storage.
Puig Racing windscreen. About 5” taller than the OEM one Retail $90, yours for $50. Like new, NO scratches or dings. Light Smoke color.
Motodynamic LED integrated tail/brake light with built-in turn signals. Does NOT need an LED relay, just plug it in and go. Smoke color. Retail $80, yours for $50. Has some barely perceptible specks on the lense.
Gear indicator. Why spend $150 on a Healtech when you can have this for $30? Plugs right in. Connector has one wire loose, easy fix.
OEM turn signals and LED turn signals. $10 each
Two HighFlow oil filters with new crush washers. $10 for both.
Elka Stage Four shock. Perfectly fits ‘06 to ‘11 and can be fitted to ‘12 to ‘16 with some modifications. Adjustable for length, preload, rebound and low speed & high speed compression. Remote reservoir, unknown spring weight, fully rebuildable. Better than a Penske, not quite an Ohlins. $950 new, yours for $350.
Ships from zip code 94523 (California), use your choice of shippers.
1 - 1 of 1 Posts
