1 - 6 of 6 Posts
2009 ER6n performance ???’s
I have an ‘09 and I’m trying to get the most speed out of it as possible without going too stupid crazy lol. I dropped my rear sprocket from a 45 to 42 and now I’m wondering what else I should do. Any pointers?
My opinion? It isn't worth it. If all the bike really has is a sprocket change (which I wouldn't call a performance upgrade per se), then sure, add a "performance" filter, a full exhaust and a fuel controller. With that you'll probably have spent more than half of what the bike's worth, and if all's good you might get an improvement of maybe 10% if you're lucky. It'll be a lot more noticeable in sound than in speed, but it's non negligible.
Or you could spend roughly the same amount, sell your bike, and get an older model ZX-10r with a definite performance profile upgrade. It really depends on whether you want a small power upgrade, a large power upgrade, if it's for lols or whatever else. But if you're unsatisfied with performance, a few bolt-on parts are unlikely to change that on these bikes.
I have an ‘09 and I’m trying to get the most speed out of it as possible without going too stupid crazy lol. I dropped my rear sprocket from a 45 to 42 and now I’m wondering what else I should do. Any pointers?]
2009 - almost 10 years old. Save money - buy a different bike if you want more performance.
I'm not sure why you would drop the rear sprocket. the bike really has no more top end with stock gearing as it is. On my 07 I hit 140mph indicated on the dash so probably around 125-130mph and it wouldn't go anymore I wasn't even at the top of 6th. Dropping the rear would be better if you're doing a lot of highway and want the best mpg possible but I bet a stock 650 could outrun you.
As others stated, you won’t get much more speed unless you’re willing to get into the engine and change throttle body size and a different camshaft.
One thing you can try is to reduce the weight. Lose the rear seat for a cowl, lose the passenger rearsets, lighter wheels and an aluminum subframe are the typical stuff.
Funny how so many change the exhaust for a 3-4 hp gain. You think Kawasaki doesn’t have the R&D to get the most out of their OEM exhaust? They do...
1 - 6 of 6 Posts
