1 - 1 of 1 Posts
Hi everyone I have 2008 z750, so on idle sometimes sounds like it's only running on 3 cylinders then it will correct itself, pulls away fine can take it all the way up through the rev range no problem but when I roll off and change gear and re apply the throttle it splutters and missfires and after about 5 seconds of no power it will go again fine, if I only go 30mph through the gears changing gear no issues at all it only seems to missfire and splutter when I change gear at higher speeds. Changed all 4 plugs cleaned air filter etc and still does it 🙈 any suggestions pls air leak somewhere? Dirty injectors?
1 - 1 of 1 Posts
