Hi everyone,
my light bulb was burn, however, I cannot find replacement. Please advise where to buy or any alternative bulb that I place order for min. order not 10 or more items.
Many thanks and appreciate your advise in advance.
HELLA 7507TB Natural Amber-21W Standard Miniature 7507 Bulbs, 12V, 21W, 2 Pack in Turn Signal Bulbs.
www.amazon.ca
You want an amber 12v 21watt bulb, single filament. I'd think you'd be able to take the old bulb with you to either Cdn Tire or an auto parts store and find one with that wattage in amber.
If you want LED that will vary as not all LED's are the same diameter / length and may not fit properly. They'd also need an LED flasher replacement or load resistors to prevent the hyper flash issue.
If your bulb is the same as the ones Kawa used in my 2015 Ninja 650, you need to buy the bulb with offset pins (BAU15s) - check to see if yours is standard (pins at 180 degrees) or offset.
The only place I could find them outside Kawasaki was Ebay.
