1 - 2 of 2 Posts
The M/S won't start, replaced the starter 4 times and the solenoid twice. I still cannot get the bike started as it appears to not be getting power to the starter. I've tested the voltage at the starter with the key off and on and I get no reading. Any help would be appreciated.
見る
Hi. Welcome onboard. Sometimes the lead from the battery to the starter can be faulty. Try using some heavy gauge wire from the positive terminal of the battery to the solenoid terminal of the starter and hit the starter button as a test (with ignition on).
Years ago I had a similar problem, acid had corroded the cable behind the battery connector. Cable looked fine, but wouldn't let power through.
1 - 2 of 2 Posts
