Hi All,
I live in Massachusetts and have been playing around with the idea of having my bike. Currently have a PC3 bad ace billet intake and Samson Slash cut pipes. Bike Runs good Any ideas or suggestions, I'm all ears??
Thank you,
Bc2
have you check on power commander website for settings?
i know my 2002 meanie has BAK breather with HD chrome 2 into 1 side burners and usb PC3 , using different setups still trial and error ( having some issues with back firing when downshifting around 2500 -3000 rpm) . Talked with Chris from power commander , best info was to have bike dyno , i still have to do this
my other meanie is a 2005 with Paul's breather (bad ace) ,cobra 2 into 1 and dobeck ejk , worked alot better in setup - than the pc3..
I talked with Chris Kelly from Dynojet Power Commander and was recommended two different MAPS. The 205-014 (With Baffles) and the 205-015 (Without Baffles). He told me to try both see which worked better with my set-up. I haven't tried them yet or know which is currently being used because it was already set up when I purchased the bike. I'm pretty sure once I hook up the PC3 to my laptop my PC3 will start updating firmware and software etc. I was thinking maybe I would set aside my income tax returns this year and have it run on a Dyno. Thanks for the response...Bc2
Bc2 , download program from power commander site,then look for ones Chris recommended 205-014 205-015, hook up cable from laptop to pc3 , start bike, readings will be displayed, save to computer, so you wont lose your current settings . this way you will have a starting point and can try the different maps before taking bike to dyno
Okay, I Just finished replacing fork seals and adding Progressive Fork Springs (Standard Weight) to the bike. Also, Progressive 444 shocks were added. My laptop died last week. I will look to replace during the week so this weekend I will try to hook up a laptop to the PC3. I will keep you posted.
Bc2
