Brand New: Oil & filter, OEM air filter, "Die-Hard" battery, "Motion Pro" clutch cable, OEM throttle cables.
2 years ago (2,000 miles):
Pirelli Rosso Tires F&R
Galfer Stainless Brake Lines F&R
Brake Pads & fluid F&R
Fork Oil
Spark Plugs
Fuel Line
Fuel Filter
Silverstar Headlamp
Grips
Also 2k ago:
Steering bearings greased
Swingarm & Linkage greased
Valves Adjusted
Main jets and pilot jets cleaned
Carb bowls drained & cleaned
Carbs Synchronized
Engine, carbs, exhaust, shock, fork seals, chain & sprockets, wheels, bars, & controls are all original.
No rust except for some surface corrosion on bottom of header pipes.
Fork Oil
Spark Plugs
Fuel Line
Fuel Filter
Silverstar Headlamp
Grips
Also 2k ago:
Valves Adjusted
Carbs Synchronized
