1 - 2 of 2 Posts
Have just replaced battery on 05 meanie, bike starts and runs perfectly when leaned to left sidestand up or down but cuts out when upright (fi light is then illuminated) anyone any ideas ,all connections are good, bike ram perfectly before,???
Gold Member
It's been awhile since I had my Meanie, but I remember having to unplug a couple things to get the battery hold down out of the way. One of them may or may not have been the tip-over sensor (again, it's been a bit). If this is not installed in the factory location, oriented properly, the ECU will shut the bike down. Also called the vehicle down sensor. Check out this thread to try to read the codes so you have a starting point. code reading
1 - 2 of 2 Posts
