When I put it in first gear , pull in the clutch to start it , it lurches forward like the clutch lever isn’t pulled in. I put put it in neutral and the bike will start.
When I put it in first gear , pull in the clutch to start it , it lurches forward like the clutch lever isn’t pulled in. I put put it in neutral and the bike will start.2004 mean streak with just over 10k miles
Hasn’t been ridden much the last few years because of this issue
First start up of the yr I get a click from the starter. So I put the charger on the battery and still get a click. I bump it in first gear , put it in neutral and it turns over strong and starts.
I take it for a ride , let it idle for a while. Turn it off and it barely turns over.
I put a new battery in it. Still get a click , have to bump it in first gear , put it in neutral again and it starts.
