2017 Ninja 650 Brake Bleed Sequence. Front Left or Front Right First?
This is a discussion on 2017 Ninja 650 Brake Bleed Sequence. Front Left or Front Right First? within the Ninja 650R Maintenance forums, part of the Kawasaki Ninja 650R category; Hello, I wanted to change the brake fluid in my Ninja 650. Is there a particular order to flush out the front brakes? Do I ...
Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By JumpingInFire
  • 3 Post By MillennialNinja
Thread: 2017 Ninja 650 Brake Bleed Sequence. Front Left or Front Right First?
    Newbie counterattack's Avatar
    Jan 2019
    Hello, I wanted to change the brake fluid in my Ninja 650. Is there a particular order to flush out the front brakes? Do I flush the left side caliper (further away from the master cylinder) first or do I flush the right (closer to master cylinder) first? Or does order not matter in the front?
    Thank you
    Supreme Being Ozninjaguy's Avatar
    Nov 2014
    Philippines
    64
    2,304
    548 times
    Quote Originally Posted by counterattack View Post
    Thank you
    Why are you flushing the brake fluid? Your bike is less than 2 years old.
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity - Martin Luther King Jnr.
    Newbie JumpingInFire's Avatar
    Jun 2018
    I've always heard to do the farthest first so you don't push air where you already bled.
    Quote Originally Posted by Ozninjaguy View Post
    Way to be helpful. You don't know his life. He could have a ton of miles, new lines, or another reason I'm not considering.
    AusEr6guy likes this.
    Rising Star MillennialNinja's Avatar
    Jan 2018
    282
    47 times
    Brake fluid is highly hydrophilic. I have brake fluid testers and in my high humidity area it's not odd at all to see brake fluid with above 2% water content within a year. Below 1% is good, above 2% you should keep an eye on, and above 3-4% it's bad. Once water gets into the fluid high intensity brake performance deteriorates fast, not to mention potential corrosion issues.
    If your bike doesn't have ABS, just go for it. It's relatively straight-forward. If your bike does have ABS, I'd really recommend a pneumatic brake bleeder or equivalent, since bleeding the air from the complicated circuit due to the ABS pump is often a small nightmare. I use and prefer pneumatic kits, but there are also hand-pump units.
    And finally, be uber careful with drips and splashes. Brake fluid eats paint. Cover everything likely to get dripped on beforehand (I recommend using dog training pads as used here), and douse with water afterwards just to be safe.
    JumpingInFire, AusEr6guy and xorbe like this.
    - Check out my 2017 Ninja 650's Mods & Upgrades!
    - If you're looking for some new projects, I've got a few interesting motorcycle DIYs.
    Sep 2018
    124
    I think furthest first.
    FYI Ive found a unique way to bleed abs bikes that works for me. I dont have a minivac ( i dont have a garage ) It wastes more fluid though. I put a length of clear plastic tubing over the bleed nipple, the size needs to be a good tight fit over the bleed nipple and you need a few metres of it(yes, meters(6ft for those who are metrically impaired) and run it over the handlebar or even higher if you can and then back into a receptacle on the ground. Open the nipple and start pumping. Once you have an amount of fluid in the tube and it’s running through the caliper and into your waste receptacle, look closely at the fluid in the tube for any bubbles and continue to pump until it runs clear. Be careful!!! The reservoir on our bikes is small and itll take an amount to fill the circuit and theres a lot of waste. This is best done with a friend who can keep the reservoir topped up for you.
    Once its clear, tighten the nipple pinch off the tube with small vice grips or just bend it over on itself, wrap a rag around and remove from one nipple, wipe off spillage and wash area immediately with water. Repeat for other side.
    At the end of the day ABS or not this is simple physics and you just need the fluid to displace air which will naturally go to the highest point in the circuit which is the clear tube over your handlebar.
    I might be crazy but this works for me.
    2010 ER6NL ABS
    Site Elder JustAJ's Avatar
    91343
    974
    36 times
    The general rule is start farthest from the reservoir. I can vouch for the method AusER6Guy uses, as that's what I do even though I don't have ABS. No one specifically said it, but do not get any fluid on your paint, unless you don't like your paint.
Similar Threads
  1. 2017 N1k Buzzing Noise During Start Up Sequence
    By Bc2 in forum 5th Gen Z1000/Ninja 1000
    Last Post: 03-10-19, 04:40 PM
  2. Replies: 3
    Last Post: 06-23-17, 11:07 AM
  3. Pre Ignition sequence question
    By 09ER6N310 in forum General Ninja 650R
    Last Post: 12-26-14, 04:59 PM
  4. Want to Buy: 2006 Ninja 650 Front Left Fork/ Left Shock
    By logitechspeaker in forum Ninja 650R For Sale/Trade
    Last Post: 01-24-13, 07:55 PM
  5. Specified Sequence
    By Cracker Jack in forum ZR-7 Maintenance
    Last Post: 11-01-12, 07:25 PM
