2017 Brake Pedal Replacement
This is a discussion on 2017 Brake Pedal Replacement within the Ninja 650R Maintenance forums, part of the Kawasaki Ninja 650R category; I need to replace the brake pedal on my 2017 650 after I laid it over. I figured it would be an easy job, but ...
Results 1 to 5 of 5
    Newbie sjspangler's Avatar
    May 2019
    Texas
    I need to replace the brake pedal on my 2017 650 after I laid it over. I figured it would be an easy job, but apparently I have to take the swing arm apart to get to the pedal. I can't find any videos or manuals to show me how to do this. Anybody know how to do this?
    Sep 2018
    105
    The brake is attached to the rear set bracket and that is attached to the frame as far as i can tell theres no need to remove the swing arm. Where did you hear that ?
    2010 ER6NL ABS
    May 2019
    Texas
    Quote Originally Posted by AusEr6guy View Post
    When I went to take off the bracket, I found that the swing arm pin goes thru the bracket (the bolt end, not the nut end). I thought maybe I just needed to loosen the swing arm bolt and maybe I could get the bracket out. Nope. I was hoping someone on here might have had to replace the pedal on one of these newer models. The older models don't have that issue as you know.
    Sep 2018
    105
    Why on earth would they have done that?
    2010 ER6NL ABS
    May 2019
    Texas
    I wish I knew. Turned a 15 minute job into a 2 hour job (if I can even do it).
Similar Threads
  1. WTB: Brake Pedal lever and Clutch Pedal Lever
    By 09ER6N310 in forum Ninja 650R For Sale/Trade
    Last Post: 06-17-14, 06:34 PM
  2. WTB: front brake lever, rear brake pedal
    By misha in forum Ninja 650R For Sale/Trade
    Last Post: 08-25-11, 09:59 AM
  3. WTB: REAR BRAKE PEDAL
    By Stormsmack in forum ZR-7 For Sale/Trade
    Last Post: 10-28-06, 06:59 PM
  4. Rear Brake Pedal
    By ZedKid in forum Z1K/Z750 Maintenance
    Last Post: 05-18-06, 04:50 PM
  5. Adjusting Shift Lever and Brake Pedal
    By ZRBob in forum General ZR-7
    Last Post: 01-09-06, 06:47 PM
