Where to Buy Rear Turn Signal Bulbs?
This is a discussion on Where to Buy Rear Turn Signal Bulbs? within the Ninja 650R Maintenance forums, part of the Kawasaki Ninja 650R category; One of my rear turn signals gave out and I was looking for a replacement. On the bulb itself says its a 12093 but upon ...
Results 1 to 5 of 5
    Newbie hardkhor's Avatar
    Nov 2015
    12
    One of my rear turn signals gave out and I was looking for a replacement. On the bulb itself says its a 12093 but upon searching, it doesn't look like anyone in the US really carries it. Is there another model # that I should be looking for? The only other hint I could see was the bulb says RY10W which looks like a generic turn signal model number but I'm not sure if they fit. They do look close enough though. Any advice would be appreciated!
    Edit - 2014 gen ninja 650
    Newbie ultimateman's Avatar
    Jun 2006
    Toronto, Ontario, Canada
    5
    I'm not sure the exact motorcycle model you have (bulb finder is looking for specific trim of the ninja 650). Please try a bulb finder such as https://am-application.osram.info/en#. I'm sure you will be able to narrow down models with the additional information it will provide. I'm actually here looking for replacement flushmount BA9S bulbs with 23Watts and 12Volts for my old ZR7s.
    2003 ZR-7S
    K&N Air Intake
    Sintered Brake Pads
    Battlax BT021
    G&G Mirror Extender
    Kawasaki backrest and rack (only on trips)
    Corbin Gunfighter & Lady Carbon Fiber Look Leather
    Rear turn signal to 20 watt marker conversion
    GOPRO HD Hero - AWESOME
    Front Shock spring PVC spacer mod (for heavier riders 240+)
    Nov 2015
    12
    Ended up going to a motorcycle repair shop asking for a bulb. Guy who owned it agreed that these are notoriously hard to find, especially if you're looking at OEM ones. Luckily he had a few in the back that was pulled off of broken bikes and lucked out. All I can really tell is they're 12093 RY10W 12V 10W BAU15s. Didn't wanna go LED in case I needed a new relay. Good luck to anyone else trying to find these state side.
    Also, these bulbs are used in Ninja 300s and probably 400s in the same year range/gen.
    Supreme Being Ozninjaguy's Avatar
    Nov 2014
    Philippines
    64
    2,299
    548 times
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity - Martin Luther King Jnr.
    Up-And Comer Buddhaman's Avatar
    Aug 2015
    Norman, OK
    31
    86
    I kept meaning to respond to this and forgot. I had to buy them from eBay for my wife’s 300. Oddly difficult to find for being used on so many motorcycles. Thankfully I needed one and bought two so I have a spare. I’m not sure why they chose to use such an obscure bulb.
Similar Threads
  1. Replies: 1
    Last Post: 04-25-13, 03:39 PM
  2. Turn Signal Bulbs
    By Mskembo in forum 3rd Gen Z1000/Z1000SX/Ninja 1000
    Last Post: 10-29-12, 03:32 PM
  3. Help! Can't find rear turn signal bulbs, 2006 650r
    By somniferumfield in forum Ninja 650R Maintenance
    Last Post: 08-18-12, 06:14 PM
  4. Turn Signal Bulbs
    By b1unt3d in forum Ninja 650R Accessories
    Last Post: 07-11-09, 04:33 PM
  5. Irridescent Turn Signal bulbs anyone?
    By holyroller in forum Ninja 650R Accessories
    Last Post: 12-15-07, 04:36 PM
