Valve adjustments on the 300?
This is a discussion on Valve adjustments on the 300? within the Ninja 300 Forum forums, part of the Kawasaki Ninja 300 category; Both my wife and daughter are new riders and they both have picked up 2014 Ninja 300 ABS bikes, one black one white....so now by ...
Results 1 to 2 of 2
    Newbie suncoast's Avatar
    Nov 2014
    4
    Both my wife and daughter are new riders and they both have picked up 2014 Ninja 300 ABS bikes, one black one white....so now by default I'm the service provider I used to have a triumph sprint that had shim over bucket valves and curently have a guzzi Breva 1100 with screw lock valve adjusters that I hope to trade or sell for a Ninja 1000 in the spring. Can anyone tell me what the service interval on the 300 is and what type of valve adjustment is needed? I'm assuming it's pretty simple.
    10,308
    2255 times
    The valve check interval should be in your owner's manual. I'm not sure what Kawasaki employed in the Ninja 300. The 250 was the screw lock valve adjusters.
    All my other street Kawasaki's are shim under bucket which means pulling the cams if adjustments are required.
how often should you have the valves checked/adjusted on a ninja 300?
ninja 300 shims under bucket
ninja 300 valve
ninja 300 valve adjustment
ninja 300 valve adjustment interval
ninja 300 valve check cost
ninja 300 valve check interval
valve adjustment ninja 300
valve adjustments on 300se
valve clearance ninja 300
