cheapo spike intake install / fix - Page 3
This is a discussion on cheapo spike intake install / fix within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; i have a question about that spike filter also. been looking at that on ebay for while now but i cant tell where the ait ...
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 73
Like Tree9Likes
Thread: cheapo spike intake install / fix
  1. #31
    Supporting Member uriahk's Avatar
    Mar 2012
    rome city, indiana
    905
    509 times
    i have a question about that spike filter also. been looking at that on ebay for while now but i cant tell where the ait temp sensor gets mounted and does it even mount to the base plate
  2. #32
    Supreme Being speedracer's Avatar
    Jul 2007
    9,018
    5289 times
    Quote Originally Posted by uriahk View Post
    yes it does. it will thread in on the rear bottom
  3. #33
    Rising Star dman77720's Avatar
    Apr 2012
    Las Vegas
    330
    114 times
    Thanks for the offer Speedracer but before I saw your post I found a cheap one for a Yamaha..since I only need the cone piece I should be good. I am just hoping it shows up before the weekend if not I will really be bummed
  5. #34
    Newbie fireresqdan's Avatar
    May 2012
    I am installing the cone setup and my throttle body plater is the the same shape as the throttle body, does not have the drop down area for thetwo small tubes, or any of the two rubber hoses any ideas on that and what i can eliminate and it all still work
  6. #35
    Jul 2007
    9,018
    5289 times
    Quote Originally Posted by fireresqdan View Post
    just cap those off as you would anyway. You should have two threaded holes in the bottom of the adapter plate, one is for the intake air temp sensor and the other for the crankcase breather tube.
  7. #36
    Supporting Member wineadors's Avatar
    May 2012
    Lewiston, Idaho
    164
    55 times
  8. #37
    Site Elder rkr0923's Avatar
    Jan 2009
    Alabama
    601
    70 times
  9. #38
    May 2012
    Lewiston, Idaho
    164
    55 times
    Quote Originally Posted by rkr0923 View Post
    Completely different aluminum spacer/adapter/thingy lol. No idea. I'm brand-spankin-new to these bikes. Just want to get my wish-list lined up for mods.
  10. #39
    Jan 2009
    Alabama
    601
    70 times
    I have the Thunder Tornado and it looks more like the link I posted
  11. #40
    Jul 2007
    9,018
    5289 times
    Quote Originally Posted by wineadors View Post
    this kit is a close of the procharger ( i think thats the name) the other is a clone of the thunder. I have the thunder clone but think the one in this link would flow better. ( more direct air into the TB)
  12. #41
    Jul 2007
    9,018
    5289 times
    just bought this kit. will be selling my other kit cheap. Nothing wrong with the other kit, just like the looks of this one better and think it may flow better.
  13. #42
    Jul 2007
    9,018
    5289 times
    Quote Originally Posted by speedracer View Post
    this kit is a clone of the forcewinder
  14. #43
    lee
    lee is offline
    Supreme Being lee's Avatar
    Dec 2011
    Lancaster, CA
    2,657
    1333 times
    So, I got Speedracer's handmedown spike air cleaner installed. Not too hard, looks good and seems to work well. One question...
    I now have an extra vacuum tube that used to go into the top of the right air cleaner. Red arrow here. I gather that that's commonly blocked off, or the whole vacuum switch is blocked off with plates to reduce backfiring.
    I don't seem to have a backfiring problem, so my question is whether it should be blocked off, or if there's a negative effect of leaving it alone.
  15. #44
    Jul 2007
    9,018
    5289 times
    Quote Originally Posted by lee View Post
    yep that is the hose that gets the marble. If you are installing the coasters ( reed valve block off plates ) all of the hoses, valves etc. that is with that system is removed. if you leave that open and still have the reed valves in i would think that would not be good for the engine. That tube was getting filtered air b/4 you put the spike intake on.
  16. #45
    lee
    lee is offline
    Dec 2011
    Lancaster, CA
    2,657
    1333 times
    That's what I thought, I'll get that plugged asap. I actually wasn't clear on which way the air flowed in that system. I meant to put my hand over it this morning to check, but was in a hurry and forgot.
    Thanks.
bigdogspikeairfilterinstalldirections
cut spike air cleaner cover
kn-sp3301
mean streak spike air cleaner instructions
spike air cleaner installation
spike air cleaner installation instructions
spike air cleaner problems
tcmt air cleaner
tcmt chrome cone air filter installation
tcmt spike filter manual kawasaki
