M215-009??
M215-009??
This is a discussion on M215-009?? within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; Is anyone running this "MAP" and what are your thoughts?...
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: M215-009??
    Newbie CRASH7772's Avatar
    Sep 2009
    14
    M215-009??
    Rising Star jd521's Avatar
    Aug 2010
    Kansas
    164
    Look down in this Topics section and see the topic PC III and Exhaust. Seems some fweel that map is not working well. I use the 215-007.
    Former and Proud Owner of a 07 S.E. Mean Streak. Traded 9/25/12 for a 2012 Candy Lime Green Kawasaki Vaquero.
    Sep 2009
    14
    I did review that post and a few others but most that I read seems people talk about it but aren't running it. I have a tune on it now but in my opinion is so far off compared to the others out there that it really has me in question. That and I think it's extremely rich down low and lean up top. I'll try to post my current map if I can figure out how to.
    2005 MEAN STREAK
    PCIII USB
    THUNDER TORNADO INTAKE
    V&H BIG SHOTS STAGGERED
    LOW AND MEAN CHIN/RADIATOR SHROUD
    MAPAM FORWARD CONTROLS KIT
    KEWL METAL RISERS
    NESS-TEC RAD II MICRO TEARDROP MIRRORS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Sep 2009
    14
    This is my current map from previous owner.
    2005 MEAN STREAK
    PCIII USB
    KEWL METAL RISERS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Supporting Member Rasmith's Avatar
    Lenexa Kansas
    59
    5,954
    1684 times
    Looks like they tried getting rid of a decel backfire by adding fuel at zero throttle. also, your map is not as rich as the stock 215-009 map. There are sime spots on the 20% throttle that are richer but thats about it.
    It's way richer than my map though by far
    Where's Rasmith?
    https://spotwalla.com/tripViewer.php...a53063774d60dc
    Works best with Google Chrome or Firefox
    Site Elder DreamStreak's Avatar
    Nov 2006
    Hiram, GA
    45
    998
    18 times
    Quote Originally Posted by CRASH7772 View Post
    I ran it and got 30mpg. Why don't you load it up, try it out, and let us know how you like it? The map is for your setup, not for mine.
    2006 Mean Streak
    Muzzy Big Bore Kit
    Thunder Cams
    Heads Ported by Me
    Intake Ported by Thunder Manufacturing
    PCIII-Custom Map
    Forcewinder Air Intake
    Muzzy 2 into 1 Megaphone Exhaust
    Reed Valve Block Off Plates
    Mustang Seat, Fender Bib, & Tank Bib
    Jardine Forward Controls with mini floorboards
    Kuryakyn ISO Grips with Stilletto ends
    Sep 2009
    14
    Quote Originally Posted by Rasmith View Post
    The bike has no backfire at all right now but smells of fuel at idle and lower rpms. Thanks for the MAP's as well.
    Quote Originally Posted by DreamStreak View Post
    I have 4 different maps to try right now but the weather had been rainy the last week and calling for another week of rainy weather. I know the guy that had his bike on the dyno producing the M215-009 tune likes it but is also out west. I guess I was just more curious if people were running the tune with or without the exact set up for it making them to not like it. I like the idea of the "advanced tune" and thanks to Rasmith I have 2 different ones to try out. I know the only real way to do it is on the dyno (hopefully this summer), just was looking for something that might be better than what I'm running now.
    Thanks again to everyone for their input.
    2005 MEAN STREAK
    PCIII USB
    KEWL METAL RISERS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Sep 2009
    14
    Well after trying one of Rasmith's MAP's I felt the rear cylinder building more heat than normal (could be actually running right as my current tune isn't a advanced tune). I also noticed my throttle input was 2%-98% which I corrected with the key on but noticed it was still off when running (around 3%) so I changed the values (idle and WOT) while running to the values with just the key on and got it to 0%. After that I decided to try the M215-009 map and it seemed to run rather nicely with hardly any backfiring (once or twice in a 20 minute ride with lots of off and on throttle). I guess now I just need to see where the MPG's are with this tune.
    2005 MEAN STREAK
    PCIII USB
    KEWL METAL RISERS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Lenexa Kansas
    59
    5,954
    1684 times
    Try the last map I sent for grins..Fuel table 2 was running lean for me as well..I gave it a good trial and noticed the vibration at 3K was gone, engine temp wasnt as hot and loads of power.
    Where's Rasmith?
    Sep 2009
    14
    I plan on it. Kinda just ran out of daylight and went with the commonly known rich tune for now. Might try to ride to work tomorrow if the weather allows.
    2005 MEAN STREAK
    PCIII USB
    KEWL METAL RISERS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Sep 2009
    14
    37.3 MPG's with M215-009 tune. Think I'm going to run this for one more tank before trying your other MAP Rasmith.
    2005 MEAN STREAK
    PCIII USB
    KEWL METAL RISERS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Lenexa Kansas
    59
    5,954
    1684 times
    Cool..
    I'm going back to the second map because I may have uncovered the reason for my decel backfiring. The plug on the tube that goes to the reed valves was broke in two and worthless.
    Where's Rasmith?
    Sep 2009
    14
    Cool..
    Those reed block off plates work nice. Not to expensive and easy to install, clean up the engine bay some as well.
    http://www.dollarrider.com/detail.cf...&related=short
    2005 MEAN STREAK
    PCIII USB
    KEWL METAL RISERS
    KURYAKYN ISO GRIPS
    SMOKED LENS KIT
    Rising Star carvedup's Avatar
    Feb 2008
    Pensacola Fl.
    287
    Try running this map. I leaned out the map in the 1700 to 3500 rpm range below 20% throttle. All the rest is original 215-009 map. Fuel mileage increased and and the rich smell decreased. It's not a radical change where you have to worry about damaging your engine.
    Attached Files Attached Files
    '08 - Fire Candy Red
    Vance & Hines Big Shot pipes
    "Halfway to Thunder" air mod
    PCIII
    Race Tech fork springs
    Custom made sissy bar
    Custom made windscreen
    Custom graphics
    Site Elder Shadowblade's Avatar
    Jul 2010
    Wasilla, Alaska
    764
    338 times
    I've been running M219-009 (that's the exact setup I have) and gotten 33-36mpg but it seems to run nice no backfire on decel - I got closer to 40 mpg before the intake/exhaust change. I just downloaded the fuel economy mp and will try it out.
    Maybe I'm blind but I did not see where to download Rasmith's maps..?
215-009 mean streak
installing kuryakyn ?second generation? forward controls
pciii map for 2005 meanstreak vance & hines big shots
plugging the reed valves on a 1700 vaquero
thunder map mean streak runs hot
vance and hines big shots tornado intake mean streak pciii
