M215-009?? - Page 2
M215-009??
This is a discussion on M215-009?? within the Mean Streak Performance Upgrades forums, part of the Kawasaki Mean Streak category; Originally Posted by Shadowblade Maybe I'm blind but I did not see where to download Rasmith's maps..? He more than likely pm'd them to the ...
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: M215-009??
    Supreme Being starman04's Avatar
    Sep 2010
    1,493
    26 times
    Quote Originally Posted by Shadowblade View Post
    He more than likely pm'd them to the intended person??
  2. #17
    Supporting Member Rasmith's Avatar
    Lenexa Kansas
    59
    5,954
    1684 times
    Quote Originally Posted by starman04 View Post
    Yup..Emailed them at request. Here they are. The Yeager map is the original map off the Dyno. See my Signature for my setup. I also put it in the details window so you'll see it when you open the file. The Yeager map was based off the 215-008 map.
    The other files are based off the Dyno map. I played around with some of the leaner settings trying to eliminate a decel backfire. I all but got rid of it by minimizing the negative fuel adjustments primarily. I made random notes to the files on what I altered. Im throwing them in here for those who want
    Yeager Dyno Map.zip
    Today I found my caddman "Marble" trick went AWOL so that was probably the cause of the backfire and popping. Won't know till tomorrow. I loaded the Yeager Map back up and will try it out tomorrow.
    Where's Rasmith?
    https://spotwalla.com/tripViewer.php...a53063774d60dc
    Works best with Google Chrome or Firefox
  3. #18
    Lenexa Kansas
    59
    5,954
    1684 times
    Quote Originally Posted by Rasmith View Post
    Cool..
    I'm going back to the second map because I may have uncovered the reason for my decel backfiring. The plug on the tube that goes to the reed valves was broke in two and worthless.
    I ended up putting the Dyno map back on. Zero backfire..Zero popping at 3700RPM like I had before..
    No need to remove the reed valves at this point..That'll be wrapped into my Chuckster Winter project. Unless the weather is bad and Im bored and have all the mods collected.
    Where's Rasmith?
    Supreme Being speedracer's Avatar
    Jul 2007
    9,018
    5289 times
    what map are you running now? I am going to try and get mine on the dyno in a few days. Maybe monday
  6. #20
    Jul 2007
    9,018
    5289 times
    Quote Originally Posted by speedracer View Post
    trying to upload the map i am using but can't seem to do so. Help please!!!! I am using a dynoed map from another member.
  7. #21
    Lenexa Kansas
    59
    5,954
    1684 times
    Run your bike to the hotel Here in Hilliard..I have the maps on my laptop..
    Bring a jump drive with you too and I will load you up with what I have...
    Where's Rasmith?
  8. #22
    Site Elder rbthntr64's Avatar
    May 2010
    Show-Me State
    598
    12 times
    Rick,
    Mine is running way hotter than usual. I need to try a different map. It acts way rich at low throttle, and lean at the top. MPG is around 35-37. I am going to see if Aaron will run it again to try and work it out. That last run was a little qwerky.
    Riding in honor of my Dad.
  9. #23
    Lenexa Kansas
    59
    5,954
    1684 times
    Are you still making it Saturday? Supposed to get down to 80 as a high.
    Wonder if you have something else going on there..I was concerned to see the a/f wig out on the high rev. Almost makes me think the TPS is acting up.
    Where's Rasmith?
  10. #24
    May 2010
    Show-Me State
    598
    12 times
    Guys, Tried to unzip both files and Winzip is say they are unsupported. What format did you guys zip them in?
  11. #25
    May 2010
    Show-Me State
    598
    12 times
    Are you going to be there Rick? Still planning on it unless my bike is broke (
  12. #26
    Rising Star vzDean800's Avatar
    Elora, Ontario
    266
    34 times
    Try the last map I sent for grins..Fuel table 2 was running lean for me as well..I gave it a good trial and noticed the vibration at 3K was gone, engine temp wasnt as hot and loads of power.
    Hey Rasmith, what map are you referring to in this post? I have downloaded the yaeger.zip maps. I am currently using Carvedup's economy map, it works well, but I am getting a vibration around 3k, thats why I wouldnt mind trying the last map you refer to.
    Dean
    2004 vz1600, V&H Big Shots Staggered with Smartpartz quiet baffles, Chuckster intake, PCIII, Mapam forwards, Chin spoiler, MM angled risers, DaveDavis hotbox, Suzuki Boulevard billet mirrors, brakeaway throttle lock
  13. #27
    Lenexa Kansas
    59
    5,954
    1684 times
    Quote Originally Posted by vzDean800 View Post
    Dean
    Im using the Yeager map but Im getting the same vibration..Not too bad but I notice it and right about 3K too..
    Where's Rasmith?
  14. #28
    Lenexa Kansas
    59
    5,954
    1684 times
    Quote Originally Posted by rbthntr64 View Post
    Im going to be there..My niece is going to ride along and hold the poker hand..
    Need to figure a meetup place. I'm flying back to KC early tomorrow so I'll look at place thats easy to get to.
    Where's Rasmith?
  15. #29
    Lenexa Kansas
    59
    5,954
    1684 times
    Sending them to your Gmail account
    Where's Rasmith?
  16. #30
    Newbie MeanStreaking's Avatar
    Oct 2018
    Yeager map
    Can you link that map? I would like to try the yeager maps but cant find them....
215-009 mean streak
installing kuryakyn ?second generation? forward controls
pciii map for 2005 meanstreak vance & hines big shots
plugging the reed valves on a 1700 vaquero
thunder map mean streak runs hot
vance and hines big shots tornado intake mean streak pciii
