2003 mean streak clutch replacement
This is a discussion on 2003 mean streak clutch replacement within the Mean Streak Maintenance forums, part of the Kawasaki Mean Streak category; Hello all, I recently disassembled my clutch to install the judges washer kit that I purchased from bad ace before they stopped operating. I figured ...
Results 1 to 7 of 7
  • 1 Post By Ken
Thread: 2003 mean streak clutch replacement
    Newbie DespicableDan's Avatar
    Apr 2018
    Upstate, SC
    18
    I figured while I was there I should inspect the clutch discs although my bike has less than 10k miles, I've noticed some slippage.
    I'm no motorcycle expert, but I do have some technical experience. When disassembled I found all of the steel disks had multiple blue parts which says to me they have gotten very hot at some point.
    I ordered a set of Barnett carbon friction plates, but was surprised to see that they came when 8 because when I disassembled mine there were only 7????
    I also need to order a set of steel rings, but was curious what thickness I should order, as I would have expected just one size available.
    Wondering if someone can advise. Thanks
    2003 Mean Streak, V&H Longshots, PC5 w/Autotune, Bad Ace Intake, National cycles Vstream
    (For Sale) 1996 Vulcan 800 (Black), 8500miles, Viking hard bags, Hypercharger, debaffled
    Apr 2018
    Upstate, SC
    18
    alright update.
    I had misplaced one of the friction plates while disassembling the clutch. I saw it this morning, and so now it makes sense why the new Barnett one came with 8 plates.
    I also went out and measured the steel plates, and found 6x .077 and 1x.062 which basically makes 2mm x6 and 1.6mm x1
    only question now is if the order of assembly matters.
    lee
    lee is offline
    Supreme Being lee's Avatar
    Dec 2011
    Lancaster, CA
    2,657
    1333 times
    There's nothing in the service manual about ordering the friction and steel plates, just alternating.
    The torque limiter spring placement is very important though so be careful with them. It's easy for them to slip and get bent when tightening the clutch nut if they're not stuck together and on the holder well.
    Newbie SPAM's Avatar
    Sep 2018
    65
    6
    Lightbulb friendly dealer?
    If your local Kaw dealer parts department is friendly, ask them to pull up the clutches on their computer and one of the steel plates should have different part number than the other six. The exploded view should show what position the odd one is in.
    maybe...
    Ken
    Ken is offline
    Gold Member Ken's Avatar
    Feb 2002
    Mendon, MA
    558
    This should pull up a pic of the clutch components: https://www.partzilla.com/catalog/ka...1500-p2/clutch
    There are apparently 3 different sizes of separator plates, 1.6mm, 2.0mm, and 2.3mm, to allow for setting the clutch pack thickness and free-play. The friction plates appear to be all the same. I'm assuming that Barnett selected the separator plates by measuring the clutch pack all together and adjusting accordingly to get within total thickness spec. I'm guessing that it makes no difference where you put the thinner one, though I'd put it somewhere in the middle. I prefer the more rigid plates at the ends to reduce flexibility at the application points.
    SPAM likes this.
    Ken
    Looking for Amsoil products? www.kgsynthetics.com
    1998 Honda Valkyrie
    2006 Triumph Scrambler
    2003 Kawasaki Vulcan 1500 Mean Streak
    2001 ZR7S
    ZR7OA member #232
    Up-And Comer giddyup's Avatar
    Jan 2014
    ontario
    96
    39 times
    was their any indication that the clutch was failing ? reason i ask my wife's 2002 has 38000 kms and my 2005 has 82000 kms .
    as far as i know they have not been changed .
    <a href=http://s1193.photobucket.com/user/notfree123/media/2005%20mean%20streak/20140126_155240.jpg.html target=_blank><img src=http://i1193.photobucket.com/albums/aa342/notfree123/2005%20mean%20streak/20140126_155240.jpg border=0 alt= /></a>
    Apr 2018
    Upstate, SC
    18
    So I ordered the judges washer kit, and wanted to install it because I wasn't impressed with the engagement. I did feel like at times it was slipping.
    I opted to disassemble everything while having it apart so I could inspect it, and was a little surprised to see all the bluing from heat all over the factory steel disks. At that point I decided to just replace it all with a Barnett kit.
Similar Threads
  1. Replies: 6
    Last Post: 10-24-17, 04:05 PM
  2. Replies: 5
    Last Post: 02-27-15, 01:59 PM
  3. Mean Streak Clutch - How do I know when its wearing out?
    By MeanRob in forum Mean Streak Maintenance
    Last Post: 05-11-10, 08:35 AM
  4. WTB: Stock Foot Controls and Clutch Reservoir For 01' Mean Streak
    By WhiteTrashMF in forum Mean Streak For Sale/Trade
    Last Post: 02-17-09, 01:28 PM
  5. Replies: 4
    Last Post: 06-02-08, 06:48 PM
2003 kawasaki mean streak clutch type
2003meansreaksampsonripsawpartnumber
